Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchen Aid KSM90 300watt Ultra Power Mixer
The chrome/metal band above where the beaters attach fell off during use. There does not appear to be any screws to reattach it other than pressure. Nothing we do can get this piece to stay attached where it belongs including tapping it with a rubber mallet. Any helpl would be appreciated.
  • NBAA Dec 05, 2008
    I just had the same problem on the same machine! help needed PLEASE!
According to the service manual this is the drip cup and is really only held on by friction. I have not tried to take my mixer apart yet but I would think that if your drip cup is too loose, all you need to do is come up with something (string, paper, saran wrap, etc) that will not actually glue it together but will add sufficient thickness to help hold it in place.
Posted on Dec 31, 2008
Where can I find beaters at the lowest cost for the KitchenAid Ultra Power Soft Start 7 Hand Mixer?
We sell the beaters at The Mending Shed, they are $8.95 for the set of beaters.
Here is a link to those on our website: http://www.mendingshed.com/kahandbeater.html
Jun 15, 2013 | KitchenAid Food Mixers
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
Aug 27, 2012 | KitchenAid Food Mixers
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
Canot take the beater out of the mixer.when I have mix my my cake I cant get the beater out to clean the beater.
counter top appliance number for kitchen aid is 1-800-541-6390 M-F 8-8 EDT, and Sat 12 -5 p.m.
Oct 21, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food made with KitchenAid Stand mixer tastes like grease
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
Feb 17, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid Classic mixer
There are 2 possibilities, the attachments are worn out where they go on the shaft, simply replacing them could fix it, the other is the shaft is worn out inside the planetary ( where it spins), if it moves allot, 1/8 " or more from side to side, the housing is probably worn, and the planetary needs to be replaced, easy job, don't know cost, a new mixer may be in order.
Dec 26, 2008 | KitchenAid K45SS Classic Stand Mixer
Spare beater
http://www.marbeck.com/mixers_kitchenaid_parts.html
heres link for replacement parts
my recommendations i would go with new parts but some will like to do the work them selves
Jun 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
285 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
