Question about Kenmore 62622 Electric Dryer
MY DRYER IS COOKING MY CLOTHES
Even on the lowest setting my kenmore dryer drys my clothes so thoroughly they smell almost burnt. It IS old but cannot afford a new dryer at this time. HELP!!!
    Problem Solver:
  • 10 Answers
Check your air duct. make sure its not blocked up with lint. also there could be a problem with one of your thermostats.
Posted on Feb 10, 2007
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
What's your problem? burnt smell in clothes
I would check your exhaust line, because all the symptoms you are listing are caused by a restriction in the air flow.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | Maytag MGDX500XW Dryer
My dryer smells like sulfur . The clothes smell
Run a couple of hot washes with no clothes in the machine
Before you do dissolve some Soda Crystals in 2 liters of hot water and put them into the machine by hand.
Your machine smells because new powders wash at lower settings and do not contain bleaches and soda to kill off the grease which is washed off the clothes
Jun 16, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Feb 21, 2009 | Kenmore 73952 Gas Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
My clothes smell burnt
If you have done any recent painting or drywall work, oftentimes the dryer will breathe these fumes and it will affect the smell of your clothes. (Just had the same problem) Maybe let the area air out and see if that corrects your problem
Nov 28, 2007 | Kenmore 74832 Gas Dryer
Dryer must have ignited lint inside the cabinet " smells like burnt popcorn" now the dryer takes forever to dry the clothes.
check your venting !!! run a load with out the vent pipe on the back see if it drys normal if so your problem is in you vent duct to the outside
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Kenmore 62622 Electric Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
