USB hub port
Trying to charge mp3 player and get power surge on hub port. I can reset it by clicking on the icon but as soon as I plug it back in, I get same warning. Any suggestions?
Thanks
  • 1 more comment
  • fishman25401 Dec 04, 2008
    No dirt and everything looks good. Are there other things to try? Can't get the software to download.
    Not sure how to do that. I'm not good with computers, but can do it with guidance.
  • fishman25401 Dec 08, 2008
    No. Had the same problem one time before but was able to get it to work, but I can't this time. Has to be something simple that I am missing.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Sounds like a hardware problem, most likely a partial short or conductive dirt or corrosion of the USB connector of the MP3 player. Since there are only 4 terminals, 1 side is for the ground, the opposite for +5VDC and the two at the middle are for data, it would be possible to check for continuity using a DVM or VOM and determine if the +5 terminal is shorted to the GND. Alternately, you can try to clean and scrape the pins.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 04, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    I understand you tried the alternate, clean, but no joy. Have you tried the primary proposal, continuity test on the 4 terminals?
    Cheers.
  • Louie  Role
    Louie Role Dec 05, 2008
    Do you have access to a continuity tester (VOM or DVM)?
We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
Mar 19, 2017 | RCA Audio Players & Recorders
Power Surge on USB Port
I'm assuming you're not using a hub but plugging directly into one of the USB ports on your laptop?
First, have you installed all current patches for your PC? I think this was a common error message that was hotfixed some time ago, so be sure your OS is up-to-date. If so, you could try to uninstall all USB ports in device manager, then restart. When your system is up, go to the first USB device and right-click, then turn off warning messages. This is just for the error message, you may have a problem with your Zen as well so try it on a different PC if possible but I'd do that when it's fully charged. You may need to do a hard reset (instructions in your manual) to get it to work but that may delete all of the Zen's contents, so that's a last resort.
Aug 05, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
USB Hub port
not sure which mp3 player you have but some will reset to default factory settings if you allow battery to completely drain then fully recharge.try it i find they "unlock"8 out of 10 times.richardm69
Dec 03, 2008 | Computers & Internet
Zune 30 Power Surge
You might have too much power in use from the USB ports on your machine: Try unplugging some USB devices you do not need, and trying again.
I have this issue with several devices I own: not really with my zune, but I never charge it with the PC: I use the AC power adapter, which I STRONGLY recommend any zune owner purchasing.
Oct 05, 2008 | Microsoft Zune JS8-00001 Digital Media...
Ipod
I think you have a sort in your ipod.
I will say a bad battery will cause this.
You have to open it and see if you make it to work without the battery.
Aug 04, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod
maybe bad ipod try another computer
CREATIVE ZEN V-PLUS. COULD NOT TURN ON AND IS NOT CHARGING
Try using the reset botton while connected to the computer via usb cable , it worked for me.
Jul 24, 2008 | Creative Labs ZEN V Plus MP3 Player
No charge...
Hello mandag78,
The error message you are talking about occurs when a device tries to draw more power from the USB port then the port can provide,
Make sure you are connecting the MP3 player directly to a USB port on the computer or a USB hub that has an independent power source (one that you plug into an electrical outlet). If you are plugging your MP3 player into a USB keyboard or a non-powered hub the port may not have enough ower to charge it.
I am assuming tha tthe Zen was working before? And that you are sing the exact same USB port and cord that you were using to charge the item previously? If so, then what you are experiencing might be a sign that the unit has failed and is in need of repair.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
