Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel will not drain
Completed the wash cycle then stopped. The washer is stopping at the rinse stage, full of water. It is not sensing that it is still filled up with water and thus will not drain.
Is there a sensor that may be out?
  • vbarnard6 Jan 05, 2009
    My Fisher & Paykel GWL11 washer also stopped after the wash cycle and won't spin or drain. My machine is only 4 years old and 4 months out of warranty.
    Problem Solver:
  • 7 Answers
I don't think so
Posted on Jan 01, 2009
  • Jim D Jan 02, 2009
    replace the pump
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Posted on Dec 07, 2008
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
During a normal washing cycle the machine stops at "rinse"
see if it takeing water out it will not let any more water in if there is water in try puting on a drain and see if its emptying if not there is a blockage in your wast pipe or your pump as gone i would try and clean your waste pipe1st and see if your pump works if your pump as gone and you need to get your water out try and move the washer near a door to the out sie and lie the waste pipe flat this will let the water go hope this is some help stuart
Jul 02, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washer will not drain water out properly
you may need to take the pump apart as it may be clogged.
Apr 09, 2009 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
314 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
