My new tone music/intercom im-4006 series was working fine and suddenly has a constant buzz sound along with music. Where can I find a person to repair my unit?
I actually want to find a service person in my area to come fix it.
Thank you
Posted on Dec 05, 2008
What would cause a buzz in speakers?
There are many causes of buzz, so it should be checked step by step :
- Bad connection on the input connector, or cord.
- Amplifier, basically have the block diagram like this. View image.25850665-l1qpqmriditabltrjczr2eku-2-0.jpg
If in one block damage, buzz can be heard.In the amplifier.
Generally occurs in the PSU and / or power amplifiers.
Fix it to the experts,because it requires a good knowledge of electronics.
Blown speaker cone, does not cause a buzz.
Short circuit along the wires supplying the audio, it will not cause any sound in the speakers, including the sound of music.
Try also, disconnect the input connector, whether the buzz is still audible. If after the input connector is removed, the buzz disappears, the possibility of buzz came from another device before the amplifier.
Sep 05, 2015 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Constant tone on start up
Press and hold the power button till it shuts off then try again.
If more help is needed include make and model number.
Aug 29, 2014 | Computers & Internet
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
When i download music tone to phone it is in download history. how to i insert to a contact
Similar to all Android phones, open up your contact list and find the person who you wish to apply the ringtone to. After opening up their contact information, scroll down and find the button that says something along the lines of "Add Sound/Ringtone". Then hit save contact. Good luck!
Mar 20, 2011 | HTC Aria Cell Phone
Working fine for the last 20 years with my arcam delta 290 then whilst on my ps3 the av processor started to make a buzzing tone through all speakers. tried all the different modes, unplugged, checked...
In nearly all cases buzzing on audio equipment is caused by faulty leads or having leads in close proximity to EMF sources. Remove all the input and output leads, does the it still buzz. Connect the speaker leads, does it still buzz? Then connect the input leads one at a time. This should pinpoint where the problem is. If you find a faulty lead, swap it out for another, new quality lead that is shielded. Others have the same problem :>(
arcam delta 290 buzzing Google Search
Jun 18, 2017 | Kenwood Audio Players & Recorders
Cannot get dial tone on KX-T7730. Intercom feature works fine.
In a TA series system, the lines have to appear on the phone. Press PROGRAM and the CO buttons. Are they assigned? If they are, then you probably have a Class Of Service or Electronic Station Lock issue. Both of them would prevent the phone from getting an outside line.
Carl
Dec 19, 2010 | Panasonic KX-T7730 Corded Phone
I have the AT&T Model 854 4-line phone. When the phone is plugged in the phone starts toning and won't stop.
Thats because its looking for the intercom number to be assigned. as soon as you assign one in programming it will stop.
Apr 29, 2010 | AT&T ATT-974 Corded Phone
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Notification tones
Is sound turned on?
You can adjust sounds and notifications from
start -> settings -> personal (should be the first screen that opens) -> Sounds and notifications.
Im useing windows mobile 2003 so it might be a little difrent for you.
Mar 18, 2008 | AT&T 8925 Tilt Smartphone
171 people viewed this question
 Grubhead
Grubhead
