Question about HP PSC 1210 All-In-One InkJet Printer
The printer will not pull the paper from the tray -
Use resume paper prior to this problem - It had a jam but finished printing - Now it will not print at all - Did everything but take it apart.
  • 446 Answers
There must be some file pending that was still queued, try to cancell all file to be printed, unless the spolled file was cleared you cannot print at all, then hit the cancel button on your printer as well
Posted on Dec 04, 2008
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Says paper jam, but there is no paper jam
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Kodak ESP 5 Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    What does e073 0003 error mean on canon 1180.
    E, 0, 7
    FINE Cartridge is not installed in the correct position
    E, 0, 3
    Paper Output Tray is closed / Paper jam
    Summary
    If the Paper Output Tray is closed, open it. The machine resumes printing.
    If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
    E, 0, 3
    Summary
    Techbelkin please rate me
    Nov 03, 2010 | Office Equipment & Supplies
    Error e03, but there is no jammed paper
    E, 0, 3
    Summary
    E, 0, 3
    Summary
    E, 0, 3
    Summary
    Techbelkin
    Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
    HP 6540 Lights flashing can't print
    This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
    The printer might be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of the printer.
    There might be a paper jam
    1. Press the Resume button. If the paper jam does not clear, then go to the next step.
    2. Push the two latch handles on the rear access door toward each other, and then remove the door.
    3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
    4. Replace the rear access door.
    5. Press the Resume button.
    If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
    1. Turn off the printer.
    2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
    3. Remove any paper inside the printer.
    4. Open the duplexer.
    5. Remove any paper from inside the duplexer.
    6. Close the duplexer, and then re-attach the duplexer to the printer.
    If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
    2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
    3. Remove any paper that is inside the printer.
    4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
    5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
    1. Tilt the Small Paper Tray
    2. Open the lower door
    6. Remove any paper that is inside the accessory.
    7. Close the accessory, and then secure the back lever to close the accessory.
    8. Re-attach the accessory to the printer.
    Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
    How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
    There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
    Sep 21, 2009 | Samsung CLP-510 Laser Printer
    PAPER JAMMED-PRINTER HL5150D
    Hello a_bowen1
    You can clear the jammed paper as follows.
    Note
      • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
      • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
    1. Pull the paper tray completely out of the printer.
    1. Pull the jammed paper up and out of the printer.
    1. Press the cover release button and then open the front cover.
    1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
    hl50_05712.gif Caution
      To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
    1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
    Note
      If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
    chap0615.gif Caution
      After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
    1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
    1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
    1. Pull the Duplex Tray completly out of the printer.
    1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
    1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    hl50_047.gif Caution
      To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
      If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
    1. Put the drum unit assembly back in the printer.
    1. Put the paper tray in the printer.
    1. Close the front cover.
    Good Luck and don't forget to leave a rating based on my solution:
    Mark
    Apr 04, 2009 | Brother HL 5150D Laser Printer
    Constant yellow blinking light, no paper jam
    I found this on the HP support site:
    The power light is on, and the resume light is blinking.
    c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
    Solution
    Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
    Solution
    1. Remove the paper with fresh ink.
    2. Press the resume button.
    The printer might be out of paper.
    Solution
    1. Load paper in the paper tray.
    The printer might have a paper jam.
    Solution
    Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
    OR
    if the print carriage is stuck or making a grinding noise, then follow these steps.
    Solution
    1. Lift the top cover of the printer.
    2. Turn the printer off and then on again.
    3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
    4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
    5. Remove the print cartridges and close the top cover.
    6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
    7. Open the top cover, reinstall the print cartridges, and then close the top cover.
    The printer may be ready to eject banner paper.
    Solution
    Press the resume button to eject the banner paper.
    Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
    HP PSC 1210 All-In-One InkJet Printer Logo
    46 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
