Question about Toshiba Satellite A135 Notebook
Cd won't burn
When I try to burn a cd, the disc pops out and says insert a valid disc. They are new disc that I've used (out of the same pack) before and they've worked properly. Yesterday I defragged my computer and it hasn't worked since. I don't know if it's a coincedince or this an entirely different problem. I've also scanned it and received a code 10. Also, I uninstalled the driver, restarted the computer, it installs another driver and it still doesn't work. Please help.
  • 148 Answers
Try to updade your CD/DVD writer FIRMWARE
See on toshiba web site the model of your laptop...
download and install the firmware...
or try to clean the laser lens...
Good Luck!
Posted on Dec 04, 2008
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Hi! I inserted a burned dvd r into my Mac but it's not reading it. The message You've inserted a blank CD pops out. I tried using a PC but it can't open it either, it says there's an error...
there are a few reasons why
1.) the formatting of the disk may be formatter for a PC and NOT a MAC
2.) after burning, this dvd was never "closed"
3.) You burned a coaster
good luck
Jun 06, 2011 | Computers & Internet
How do i format a disk??
Format a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Apr 05, 2011 | Microsoft Windows XP Professional With...
Disc drive no longer reads discs, when trying to burn error "please insert empty disc" pops every time, regardless of CD inserted.
Assuming you have already tried a cleaning kit, the unit has probably burnt out the laser and will need replaced. Luckily new DVD+R burners can be found for less than $25.
Mar 17, 2010 | Dell Dimension E310 PC Desktop
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
Mar 10, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
VGC-RB30 DVD/CDR DRIVE
You actually perhaps using a non blank disc at that time. Burners don't really accept non writeable Discs. Check your CD first before burning. If you are using a rewriteable disc (CD-rw) that has files, it can burn and files will be overwritten but if you're just using a CD-r with files in it, the burner will eject and will tell you to insert a blank disc.
Dec 22, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
I'm trying to burn an audio CD, I just bought a new pack of blank CD's the same exact ones that I've always used. I'm trying to burn through Musicmatch Jukebox-which I've also always used, but the CD's...
Click on Start ==> RUN ==> Type REGEDIT ==> Click OK.
A registry Editor Window will Open. then follow the Path given in Picture. Once you delete Upper and Lower filter restart your computer and then Try to Burn Cd. you will be able to Burn CD.
Nov 26, 2008 | Computers & Internet
CD-R problem
If this is happening it's usually a sign that your drive is failing as it can no longer read the media type, but just double check, if you are using Nero that you havent got DVD highlighted in the start smart as the media to burn to.
Sep 06, 2007 | Sharp Actius MC24 Notebook
Toshiba Satellite A135 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
