Question about LG 42LC2D 42 in. LCD HDTV
My lg telly has no sound or picture power button just flashing red
    Problem Solver:
  • 7 Answers
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Posted on Jun 24, 2012
3 Suggested Answers
SOURCE:
SOURCE: LG RZ-42PX11 42
Common problem. See this site -
http://www.forums.hcsd.com.au/Blah.pl?v-print/m-1175589480/
Posted on Jul 09, 2008
freelance-au
  • 131 Answers
SOURCE: 42LG5010 When switching the telly
I would start by shining a torch at the screen when the TV is turned on and see if you can see a faint image in the background, if you can then this would more than likely be down to your inverter board/s
If not then if you have no picture and no sound at all then i would put this down to your main AV board (the one with the scarts and inputs on )
These guys have all boards for this TV
LG LCD Spares
Posted on Mar 27, 2011
LG 4200A
hi the problem wouldnt be the screen instead your probably right with the video card if the screen was dead it would stay black but with it changing slightly you know the screen is gettin power.
When you press the controll does an led flash on the telly to tell you the controll is working just incase the telly is stuck on an av channel.
If you have got a dvd player hooked upto the telly switch this on with the telly on and see if the telly will work using the dvd player this would rule out the fault being with the ports on the telly not picking up the signal.
If this still dont change anything then it could either be a resistor gone or a couple or it could be what you thought with the video card/controller but their is no way of knowing without testing the resistance at certain points on the board but it deffinately wouldnt be a problem with the screen so it shouldnt cost to much to repair.
It mgith be a case that the telly has overheated and blown a resistor thse can be brought for pennys but locating will be the problem let me know what you want to do and wether you are considering doing the repair yourself if you are you will need schematics to follow off and also multimeter to test resistance at certain points on the board.
Jan 16, 2008 | LG 42LP1D 42 in. LCD HDTV
Lcd tv light flashing but no picture or sound
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
Dec 06, 2012 | Bush Televison & Video
42LG5010 When switching the telly on the red light flashes then to blue light comes on to show we have power but no vision or sound
LG LCD Spares
Mar 27, 2011 | LG 42LC2D 42 in. LCD HDTV
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
When I turn it on (with remote) it goes from standby mode (red), the light flashes, then I hear a click and the light stays on white but I cannot get a picture. I have to turn the telly off and on several...
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com for a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 42PX4DR 42 in. Plasma TV
LG FLATRON PLASMA TV PICTURE KEEPS GOING RED
starting with screen, there is a problem with HV transformer and just an expert can fix it. The sound's problem is from your jack's cable. Replace the Jacks and there no must be the problems! Rateme if i've help you. Thanks!
Sep 14, 2009 | LG Studioworks 700S 17" CRT Monitor
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Code for 32 in lg tv to work with sky control
TV
RED + SELECT
TV
0056
try the power button if this switches off your telly press select to save the code if not repeat TV and then Power until it does... remember to press select once it knocks your telly into standby.
if you have not joy with this then you are going to have to get a newer sky remote. if you take the battery cover off the back of the remote you will see a sticker on there saying REV 4,6,8 the higher the number the newer the remote. then do the process again.
0056 is the manufacturers code for LG
Cheers
Little Dish Fitter
Mar 09, 2009 | LG 32LG30 32 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
88 people viewed this question
RONALD CARTER JR
