Question about Euro-Pro 373 Mechanical Sewing Machine
How to oil euro-pro 373
The mashine does not drawing up the bobbin thread
Usually the needle is in backwards
Posted on Jan 11, 2010
Will no pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Euro-Pro 373 Mechanical Sewing Machine
Bobbin cover plate
click this link directly.http://www.euro-pro.com/europro/categorybrowse.aspx?cat=Sewing(EuroPro) ------------- this is direct link for the service center.you will have to enter the model number and place the order.this will help you.
Sep 16, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Needle does not pick up bobbin thread on my 373 sewing machine, flipping the bobbin does not work, as someone suggested.
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Jun 11, 2009 | Euro-Pro 373 Mechanical Sewing Machine
How to oil euro-pro 373?
Have you tried flipping the bobbin in it's case, so that the thread comes off the top of the bobbin instead of the bottom. Some machines are sensitive to one direction of the bobbin thread.
Dec 04, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Bobbin won't thread
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
Oct 09, 2006 | Euro-Pro 373 Mechanical Sewing Machine
Euro-Pro 373 Mechanical Sewing Machine Logo
96 people viewed this question
Top Euro-Pro Sewing Machines Experts
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
