Question about Reddy Heater-30-55,000 BTU Variable
I have an R50 Reddy heater. It will start and run and heat for about 4 mins, then it shuts down. Then I push the reset button and it will run approx. 5 soconds then shut down. What do I do and will it be expensive?
  • 232 Answers
If the heater runs good & smells good while its running, but shuts down for no apparent reason, then most likely, you have either a bad Safety Control HA3003 (reset) or a bad photocell HA3019.
But, don't rule out simple problems like:
(any of the following can cause a flameout condition, in which case the photocell will shut the unit down. This is where trouble shooting comes into effect).
  1. loss of ground at the Ignition Control (transformer)- not screwed down good
  2. restricted fuel fulter
  3. restricted or worn nozzle
  4. air pump pressure not set to specs
troubleshooting tips
Posted on Dec 05, 2008
My heater will shut down after running for about 10 mins. there is lots of propane, and all the connects seem to be tight and secure. i've checked the gap in the sparking unit (spark plug) and its around...
Hi check the flame sencer is clean check tubes to pressure switch ,jump out presureswitch , check fan control switch is clean, agian jump this out see if it works then .
Feb 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
Nov 12, 2009 | Tools & Hardware - Others
How do i light a Reddy Heater rcp 2000 lp gas heater?
hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Sep 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
Oct 12, 2017 | Reddy Heater-30-55,000 BTU Variable
Does it have a themostat?
The R50 has no thermostat.
The two knobs... are they screws? In the round black plastic end cover? If so, do NOT adjust because they are not a thermostat, instead, this is the heartbeat of the fuel system. The air pump pumps fuel to the nozzle and atomizes the fuel. If you have adjusted the one with a hole in it you will need to reset the pump pressure. It's easy!
http://reddyparts.com/pressure.htm
Nov 28, 2008 | Reddy R60A Utility Heater
I have a reddy heater model r 50.. It ran for an hour, then shut off, I f I reset it, runs for 15 min or so shuts off... its old and borrowed, I think i might have a thermostat on it and just shuts off...
The R50 does not have a thermostat.
The 2 knobs that you mention- are they the screws in the black plastic end cover?
If so, these are the heartbeat of the fuel system and do not adjust. They adjust the air pump pressure which puts fuel in the nozzle and atomizes it. The pump pressure is critical. If the pressure is not correct the heater will shut down.
If you have adjusted the screw with a hole in it you will need to reset the pump pressure to specs. It's easy. http://reddyparts.com/photocell_test_sp.htm
Now, if you have not adjusted the pump, then you might want to check the tank for water.
Troubleshooting tips
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
540 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
