Question about Panasonic CT-34WXD65 34" TV
Dark area on screen
I have a Panasonic CT-34WX54 34" and I noticed I have a dark area in the middle of the left half of the screen. It is a circular area about 6 inches wide. I notice it mostly during sports or nature pictures where there is a solid background. It isn't noticable during normal shows but during sports like basketball and football you notice that part of the field or court is darker. Is this repairable and what might be causing it? When I show other people the is issue, they see a dark verticle band from top to bottom. I mostly only notice the circular area.
    President:
  • 1,284 Answers
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Posted on Feb 08, 2007
3 year old Panasonic VIERA TC-P54VT25 screen has a series of horizontal red dots from left edge to middle of screen in lower half of screen. Visible when the picture is dark. Not so visible when the
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2014 | Panasonic Televison & Video
Panasonic viera - power on, half screen dark/ half light. Goes on and off apx 3 times then disappears unit power reset then repeats.
I think u Panasonic viera creating these problems due to magnetic field around d area,so suggestion is that keep away magnetic devices like ur speakers etc & may be ur TV pitcure tube was damage so u have to go for a repair man....thnx for giving me ur important time..:(
Aug 06, 2013 | Televison & Video
Panasonic TV TC-2175C, display turning dark
There are mainly two reasons for this fault. The first one is with its screen voltage settings. If the screen voltage settings have gone down [it can be happen automatically in rare cases], the screen will look dark. The second one is with its video output section itself. Anyway, you have to seek an experienced service technicians' help in this matter, if you are not handy in electronics.
Jul 02, 2012 | Panasonic CT-27G13 TV
Panasonic 51 inch rear projection--bought in 98 has dark picture
http://www.purelandsupply.com/Panasonic-Projector-Lamp.html or go here and call them @ https://www.interlight.biz/ they will answer any question and are half the price most of the time, please give me high rating
Apr 16, 2010 | Panasonic CT-27SL14 27" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Red Bowed Lines / Red Hue
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Californian.
Jun 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Hitachi 57F500, Dark areas
Hitachi dark problems at ctechnicians.com
Dec 27, 2007 | Hitachi 57F500 57" Rear Projection...
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic ctp2780sf Picture very dark
check the ABL at the flyback and solder any bad connections there. U can increase the brightness at the flybacks buttom control .
Dec 29, 2006 | Panasonic CT-27SF25 27" TV
Televison & Video Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
