HARD DRIVE POWER FAILURE
I'VE TRIED EVERYTHING THAT YOU GUYS TOLD ME TO DO , BUT YET AND STILL EVERY TIME I CONNECT THE HD TO THE POWER CONNECT ON COMPUTER THE SYSTEM,LIGHTS FANS EVERYTHING SHUTS OFF! HELP PLEASE. RESET JUMPERS. IDE CONNECT CHECK /TRIED IT ALL
  • ANGIECECELIA Dec 05, 2008
    THE SYSTEM WAS POWERED OFF COMPLETELY WHEN HD INSTALLED, BUT AS SOON AS I MADE CONNECTION THE FAN AND EVERYTHING SHUTOFF AFTER A SPIT SECOND OF
    TURNING. CHECKED HD/IT IS WORKING! MORE HELP ! PLEASE
    i tried the hd in a different computer and it worked.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The HD's power connector and IDE should only be connected when the power is OFF. If you have done this and the PC will not power on, then the HD is defective. Sorry.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 04, 2008
  • Louie  Role
    Louie Role Dec 05, 2008
    How were you able to "CHECKED HD/IT IS WORKING" when the PC is powering off when it is connected?
  • Louie  Role
    Appreciate your quick reply and thank you for no longer posting in all capital letters.
    Three(3) possibilities:
    • the power connector of the PC is wired wrong; red +5, black & black is ground, yellow is +12. you would need a DVM to check this out;
    • the power supply of the PC has insufficient power to supply the HD. Try another HD on this computer;
    • the IDE cable is connected in reverse either in the motherboard or in the HD itself.
    Cheers.
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
I have an older ibm thinkpad laptop, Tried to add memory, a new fan The power and fan and hard drive started , then powers down
Hi There,
Make sure all of your connections are tight, and that the RAM, HD connector, and anything else you've touched is seated correctly.
If you tried to put more RAM in than the computer will allow, it will not turn on. If you've unclipped a wire somewhere or your RAM isn't seated correctly, it will malfunction.
Check and then double check everything.
Jul 16, 2012 | IBM Thinkpad T43/p Notebook
Hello, Recently I tried to back up my computer onto my EXT HD but it was not successful because of lack of storage size. Coincidintally, my EXT HD will not turn on. It all happened at the same time. I...
the problem could be from your USB. The USB of your computer might not be powering the drive.
Secondly, the hard drive wire that passes from the computer to the external drive.
Lastly, the Hard drive case could be defective and not make the drive power on.
Therefore, connect the external hard drive to another computer, in other to be sure whether the problem is from your computer's usb port or from the hard drive. This will let us know where to focus our attention.
Let me know what happens thereafter.
Take care.
Aug 15, 2010 | Computers & Internet
Hard disk doesnot detect
Hi....
If your hard drive will not be detected, be sure that your hard drive is connected correctly. Check you hard drive if it is plug in the power and the SATA or IDE cable.
Have you experience having trouble by this error, DISK BOOT FAILURE.
This is a hard drive problem witch is not correctly connected.
If your hard drive are correctly connected, try yo first boot your hard drive in the BIOS.
Hope it may helpful for you,,
Thanks for using fixya
Regards
ICmanServer
Aug 18, 2009 | HP 448337-001 - HP 520 Series Intel...
Hd power problem systemax cpu
If you would provide more information about your Systemax system... model/serial number I can look the specs up. I can tell you the only way that it could be the hard drive would be if you had a bad power supply, not that your system can't handle the "power" of the hard drive. If you end up getting a new power supply, you could opt for one with a little higher wattage if you'd like. A 160gb hard drive isn't going to pull any more meaningful amount of current than a 40gb. What I would look at would be wither you had the jumpers on the hard drive configured correctly. For info on jumpers, see...
http://en.wikipedia.org/wiki/Jumper_(computing)
Individual drive manufactures and drive models have different method for setting the jumpers and it will also very on what other IDE connected devices you have in your computer (optical drives, hard drives, Zip drives, and etc.).
Nov 25, 2008 | Dell Inspiron 2200 Notebook
POWER FAILURE AFTER HD CONNECT
Ok ATA is the standard for data transfer, in this case it is IDE. 133 is the max transfer rate. I have removed the hard drive from ours (bought from dell directly and has not been changed) and the hard drive is set as Master (no jumper). Try this if it does not work i would test the hard drive in another system or in an inclosure.
Nov 19, 2008 | Dell Inspiron 2200 Notebook
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Hard Drive doesn't show up
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Good Luck.
Live, Love, Laugh.
Mar 30, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Failure on powerup?
I suspect that your PSU is faulty... can you buy another one? This is a fairly typical of a "Blown PSU" symptom to me... I would try replacing the PSU, and then connect ONLY the Motherboard, if OK, then Hard Drive, if OK then .. and so on.. I advise this as it MAY be something connected to the PSU that caused it to "Fault" but generally they just go Toes Up for no real reason.. other than PSU component failure.
Jul 30, 2007 | EliteGroup 741GX-M Motherboard
Computers & Internet Logo
David Payne
David Payne
