Question about Nikon COOLPIX L3 Digital Camera
Not able to change flash setting - button not working
Everything else about the camera appears to be working fine, but when I try to change the flash setting nothing happens. It is currently stuck on manual w/ no flash so any pictures I take at night turn out blurry because the shutter speed is so slow. Any ideas on how to fix?
This worked for me. Thanks.
Posted on May 29, 2007
Try going into the "Menu" the "Setup" settings and "Reset"
Posted on Mar 04, 2007
How do you turn the flash off on a hp photosmart 435 camera
Hi hookerglen.
NOTE The flash does not work while recording video clips.
To change the flash setting, press the Flash button on the top
of the camera until the desired setting appears on the Image
Display. The camera remains in the current flash setting until
you change it or turn off the camera.
please fellow the instructions in the picture bellow aid you use your hp cameras flash light better.
let me know if it works for you.
Thanks.
May 11, 2011 | Cameras
My flash on my sony cybershot will not turn on. the button doesnt want to work it just beeps, but everything else works fine. Can I fix this?
Set camera on auto (green mark) and turn on flash by pressing flash sign button.
Or initialize camera by going into menu.
Aug 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera is fine except won't take pics!
1/30 is the camera speed setting which is very slow for a daylight shot.. and would possibly produce a blurry overexposed pic if it did take one
F3.5 is the aperture setting which is small.
an ideal aperture in daylight setting is F8 and a speed of 100 being relatively standard. Try changing both the speed and aperture settings on the wheel =to obtain the nearest or exactly this and then try. Otherwise it needs a service or a recharge Also try changing the battery in case there is something wriong with the one in the camera
Jul 30, 2009 | Olympus FE-340 Digital Camera
My IE8 does no longer load parts of pages (flash/java)
I would lower my IE settings as far down as possible. I would also go to Internet Options/click on Settings located under Browsing History/click on the View Objects button and delete any corrupted or none working versions of flash and java. Then I would go to adobe.com and java.com to install new version of flash and java.
Ryan S.
Jul 23, 2009 | Microsoft Internet Explorer 8
My flash on the kidizoom camera won't work
To Change your flash settings, press the Delete Button while in Photo mode until desire setting. I had the same problem!
http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf (Page 9)
Jan 15, 2009 | Vtech Kidizoom Digital Camera
Flash off sign.
I had a similar problem, where the only option on the menu for the flash was off. I initialised the camera (reset everything), and the flash options have reappeared, and it now appears to work fine (initialise is in the settings menu from home).
Dec 31, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Cameras
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
161 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
