Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral side by side 26 cu' LSD 2615 HEW
When I try to get water from the ice dispenser only ice cubes come out. Cannot get water, cannot get crushed ice.
Thanks
3 Suggested Answers
  • 738 Answers
SOURCE: ICE MAKER
Sounds like you are not getting enough water into the ice maker tray. When the ice ejector removes the ice from the tray, it may be causing the ice to splinter which is the crushing you describe. The problems could be:
* The water inlet valve
* The ice maker water inlet is partially frozen in the freezer section
* There is a problem with the water line (kinked or partially obstructed)
* The timing mechanism for the inlet water valve isn't working correctly
Check #2 from the above list first
Posted on Mar 15, 2009
woodchuck789
  • 4059 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
woodchuck789
  • 4059 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
The buttons that select water, crush or cube do not function. I can get crush or cubed ice but the water button does not work. I have tried turning off at the mains and starting again but still there is a...
remove the front cover off this selector panel(if equipped) and replace the interface board in behind here as the little switches are bad and theres no fix to these boards
Jul 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAKER
Mar 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
