Question about Sony CDP-C545 CD Player
Sony cdp-c545 won't open
We have cd's in the player ... they won't play and the door won't open .. there's a clicking sound also
    New Friend:
  • 35 Answers
Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
Once you have the discs out, put in only one disc and see if the unit plays. If you get a disc error, you probably need to clean the lens on the laser. Open the unit, use a cotton swab that has been pre-wetted with glass cleaner to wipe the lens on the laser. Do this gently, don't press down hard on the lens. Use the other end of the swab to dry the lens. Try loading a disc with the top cover off and see if it spins. If it doesn't spin, try turning it by hand. If you can't turn it by hand, the gears have gotten out of alignment.
In this case, use your screwdriver again, noting which way the gear on the bottom of the unit spins when the drawer is going into the unit. Then turn the gear until it "pops" past one or two teeth, and then you should see the laser assembly rise up and meet the clamp assembly on the top of the tray. These are the most common problems with the 5 disc players that Sony made. Many times I could fix them in 30 seconds or less using this procedure.
Posted on Mar 02, 2009
Stuck Sony CDP-CX355 Carousel CD player - door won't open, just hums
Something must be jammed so a trip to a Technician will resolve that. This is one of the reason I never buy changers of any kind because over the years I have had to fix so many cartridge, platter and other changers that are all designed poorly enough to make the 90 day period but not last too much longer. The Sony ES models are the best but they were big money back then- I have a broken one in my shop now.
Jan 23, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
My sony cdp-c500 won't play
What does it do anything- does it take the disc in and make clicking sounds? We need more info that it doesn't play to be able to offer any idea of what you are dealing with.
Dec 08, 2012 | Sony Audio Players & Recorders
How do I open manually as a cd is stuck?
Get a large paper clip and straighten it out. Then look on either side of the drawer, right above it or below and you will see a very small hole. Insert the paper clip into it and you will fel it push up against a manual switch. Slowly push and the drawer will unlock and you can pull it open.
Please rate this if it helps you. Thanks and have a great day
Jun 27, 2009 | Sony CDP-C545 CD Player
Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Sep 17, 2008 | Sony CDP-CX300 CD Player
Sony CDP-C545 CD Player Logo
688 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
