I've just bought a Goodmans Digital Set-Top Box, together with a recordable DVD player. I have set up my Digi-Box, but can only view some channels, ie; not ITV or Channel 4, etc. Do I need to buy a a Digital aerial, bearing in mind, I don't have an external aerial at my property?
Asked a colleague - sorted
Posted on Dec 05, 2008
My old samsung dvd recorder dvd/r120 doesnt work with my new digital tv. can only record 4 analogue channels worked fine before with digi box.have a digital aerial
> digi box (?)
Is this digital converter?
Your new TV doesn't need it but it could well work with your DVR. It wouldn't give you the benefit of HD recording but with it, you could convert the digital signal into analog and record the results.
Jan 02, 2010 | Panasonic DMR-ES10 DVD Recorder
Is it possible to record and play dvd through a set top box....on a tv with only 1 av channel
If you take a scart lead from av1 on the dvd into the tv,then a scart lead from the digi box into av2 on the dvd,you will then be able to watch dvd and digi box,also you can record from digi box on channel av2 on the dvd.You may have to turn off a unit to watch one.
Nov 01, 2009 | Televison & Video
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
I have a hd set top box set up to my plasma tv. I have a dvd recorder as well. How do I set up the recorder so my signal still goes through the digital box
If you connect the main aerial into the digi box,then a fly lead out of the digi box into your dvd,then from the dvd take a fly lead into your tv,hope this helps
Aug 07, 2009 | Televison & Video
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Apr 22, 2009 | Goodmans 289NS 14" TV
Recording digital channels
Connect your set top box to Scart L2 (the Right hand one).
Select Prog 1. Then Channel down until you get to L2.
This should work.
Jul 12, 2008 | JVC DRM10 DVD Recorder
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
