Question about HP PhotoSmart 7760 InkJet Printer
Will not print in Black, I have changed the cerrtridge, cleaned i several times. It is completely blocked.
  • md1950 Dec 15, 2008
    Yes I have the same problem.
    Guess I will go out and buy some brand new cartridges.
    I have been using refillable ones.
    Is that it?
    Problem Solver:
  • 8 Answers
Clean again, and try using original ink.
Posted on Dec 04, 2008
Why does my canon mg5250 not copy black and white
Go to the setup, then maintenance menu on the printer and select "print nozzle check pattern"
You should see a complete black ladder pattern (for the fat black cartridge) and a set of coloured bars for each colour cartridge (including the thin black cartridge). If the black ladder pattern is missing then this indicates the black printhead is blocked or cartridge is empty. If you are SURE the cartridge is not dry, then:
select clean to clean the print head for the black only. You may have to do this several times. If the check pattern does not improve, you may have to remove the printhead and clean it manually. Instructions to do this I will give separately if needed.
Mar 04, 2015 | Canon MG5250 Printer
- I have just changed the black ink and now it wont print so I have changed the black ink again and it still wont print anything black - any ideas
The black ink nozzle in the print head might be blocked. Print a test page with a huge black image. Like: just start word, create a square through "illustrations" and fill it completely with black. Print it once or twice and see if finally the black ink may come out.
Through printer properties (windows control panel) there might be additional cleaning options.
Feb 24, 2015 | Office Equipment & Supplies
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Will not print black only. Changed ink cartridge 3 times, performed all maintenance repeatedly, but will still not print black ink.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 01, 2012 | Epson Stylus CX9400 Photo Printer
I have a Brother MFC-6490CW that my husband purchased for me somewhere between one and two years ago. I just recently decided to use it, and the black ink would not print. I thought the original...
Power purge the machine:
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Feb 25, 2011 | Brother MFC 6490CW InkJet Printer
Changed new ink but when i print, the pages come out blank with no ink. Printing motion takes place but some how the ink done not reach the paper.
I had the same problem with my DCP 165.It simply wouldnt print.The paper was coming out but it was Blank.I had changed all the cartridges so there was no obvious issue with the ink.Then I printed a test page.It printed all the colour blocks except the black.Then i found out from Brother website that it was a problem with cleaning and after seeral cleaning cycles the printer worked fine. STEPS 1>ink management 2>Cleaning 3>Black or colour 4>OK Repeat the above process several times and try printing after that...Hope it works
Sep 15, 2010 | Brother DCP 165C Compact Color Inkjet...
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
H P 2575 Will only print black. Change Black
cleane the head using head clean option then try it
Oct 02, 2009 | Office Equipment & Supplies
Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
May 13, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
HP PhotoSmart 7760 InkJet Printer Logo
Seeker5211
Seeker5211
