Question about Microsoft Windows Server Standard 2003 for PC
How to take a back up for active directory? - Microsoft Windows Server Standard 2003 for PC
  • 1,605 Answers
There is no backup for Active Directory only. you can backup the PDC or the BDC as a whole. or to backup the system state data.
Active Directory is same as registry. backup the AD will help you any when the machine goes down. you don't have the link to all of the services.
Posted on Dec 04, 2008
What causes a pc to lose its trust relation
Must be a corruption on the active directory, you are installing a new relationship when you put them in a workgroup, check the updates between the active directory servers.
Sep 13, 2014 | Computers & Internet
Directory services restore modesafe
Start, Run "services.msc"
Right click on Active Directory Domain Service, Left on Start.
If Started then Smile. If Not Started then Read Error Message.
Nov 28, 2013 | Computers & Internet
Ldap connection issues. Issues connecting to LDAP Active Directory server on port 389. Search base setup as dc=domain,dc=local
You need to change the base DN to match your active directory domain.
So, if your active directory DNS domain is: then your DN would be: dc=example,dc=com
Hope this helps.
Dec 07, 2010 | Panasonic DP-6010 All-In-One Printer
How we can remove active directory in windows 2003 safe mode ?
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Active directory is rebuilding
if u edit settings in active directory and editing the rools
bake up your setting
and remove active directory
them stup it agien
Nov 06, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
we have a following command option to open active directory:
Sep 30, 2008 | Microsoft Office Outlook 2003 for PC
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
What is the acitiv dirctry
Dear , friend
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services,
Active directory is a directory service used to store information about the network resources across a domain and also centralize the network.
DNS stands for Domain Name Server. These are the servers that match up a fully qualified domain with the proper IP address. This is necessary because computers only understand the IP address for your domain (eg- 123.45.678.90).
Jul 23, 2008 | Microsoft Windows Server Standard 2003 for...
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
you can use in built ntbackup utility.
In a DC, in the Items to backup window, expand Mycomputer and you can see System state. select that and proceed. It will take the Active Directory data.
Nov 06, 2007 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
