Question about HP OfficeJet V40 All-In-One InkJet Printer
The copied image isn't squared evenly on the paper.
I have an Officejet v40 that's about four years old and when I copy something it does'nt come out even on the paper. The image isn't evenly spaced on the paper.
  • baldyking Dec 07, 2008
    I haven't had time to follow the instructions but it makes sense to me and I am satisfied with the response. Thanx
  • 37 Answers
What is happening is that the roller that pulls the paper through is slipping so it is pulling the paper through unevenly. You also want to make sure that the guides are snug up against your paper when you feed it through. If it has a lot of slack it can have this problem. If you open the ADF (where you put paper to copy, scan, or fax) like if there was a jam. There will be a roller You can clean these with alcohol and a clean lint free cloth. This could solve your problem but if it return the roller and the pad will have to be replaced.
Hope this helps
Posted on Dec 04, 2008
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
A vertical line appears on copies/faxes from my hp officejet v40
It has nothing to do with the wheels you need to clean the glass at the end of the scanner there is a small glass area that the paper goes over (a small dot on the glass will cause a line)
Jan 23, 2009 | Office Equipment & Supplies
Scanning to computer
I had the same problem if I use the buttons on the v40 and try to scan. I get the V40 can not connect to the PC message.
Workaround:
Go to Control Panel-->Scanners and Cameras
In there you will find: Hewlett-Packard OfficeJet V40 Scanner
Right click and select Scan. It will then start the scan wizard which will scan your document.
Dec 03, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Hp deskjet v40 printer set up
ADF means Automatic Document Feeder, used to copy, scan or fax multiple pages loaded at one time.
Aug 19, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
