Question about HP Pavilion dv6000z Notebook
My dvd rw oprtiarc ad 7561a ata is not working
My computer is not recognising d drive at all. it is not even in device manager
  • Anonymous Jan 02, 2009
    I have the same, if i do a system restore to factoryy settings its there agin till i shut down then its gone
  • Dan
    Dan May 11, 2010
    you might have a loose or bad IDE or power cable to the cd drive.
    Can you check the cables and post back?
  • 186 Answers
Issue can be related to Hardware as per your description.
I recommend you to try removing and reseating the DVD Drive manually by following the instructions available in the manual of the notebook.
You can download/open the Manual of the notebook from the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
Refer to page number 110 of 233 in the manual of the Notebook.
This should solve the issue.
Unfortunately, if the issue persists, you may have to purchase a replacement DVD Drive for your notebook.
Posted on Dec 06, 2008
Optiarc dvd rw ad-7561a ata device unplugged
Check BIOS for Optical drive. Press F key noted on boot screen to enter. If it's not noted there, you need to check physical connections. Might just need to be re-seated with power disconnected. Re-check BIOS and make sure to save before exiting.
If it is noted in BIOS and Windows still fails to see the drive. Run a thorough virus scan, then boot into Safe Mode by pressing F8 during startup. Go to Device Manager, and select Show Hidden devices under the View tab. Delete all drives and reboot. Windows should say new hardware found and install.
This should take care of the problem if there is nothing wrong with the drive. Replace or seek professional support is not, and good luck
Dec 11, 2012 | Computers & Internet
My dvd does not play error 10 device manager and yellow sign optiarc dvd rw ad 7563a ata device
Is this an internal or external drive? if it is an internal one then on the device manager screen where it is hows the yellow sign on signoptiarc dvd rw ad 7563a ata device, right click on that an click on uninstall.....And if any pop up comes up click on ok and restart the pc after that. Wait for the pc to reinstall the driver for the dvd drive. And then check the status of the dvd drive on device manager. If it does not have any yellow sigh then try again.
Feb 17, 2011 | Gateway (5500652) (  5500652)...
My optical device needs drivers
Optical drives don't need drivers, they all use the same generic driver that comes with Windows.
Jun 12, 2010 | HP Computers & Internet
The driver is not detected by laptop
Is your dvd drive capable of doing light scribe?: If not, then the driver won't make it work. It takes a special drive to use lightscribe, and it should be part of your CD/DVD burner software. I highly recommend Nero software as the best, more reliable and easiest to use. Also, it the brand that usually comes with New CD and DVD drives.
Oct 09, 2009 | eMachines T5274 Desktop PC
Optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
Feb 21, 2009 | HP Pavilion dv6000z Notebook
The Optiarc DVD RW AD-7561A ATA won't work on hp pav dv6000
Windows uses generic simple drivers for any optical drives. Try deleting the drive from device manager and reboot. You do not need to download anything special for windows to operate a drive. If you cannot access the drive then it may be damaged or a hardware fault.
Jan 25, 2009 | Computers & Internet
Optiarc DVD RW AD-7561A This device cannot start. (Code 10)
http://cr.am/framed.php?url=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2Fdocument%3Fdocname%3Dc00817052%26lc%3Den%26cc%3Dus%26dlc%3Den%26product%3D3752864%26os%3D2093%26lang%3Den&ref=driverguide
Go to this incredibly long link (sorry about that) and look though the solutions there, it says it is for hp and sony computers but it has the same principal for all dvd/cd drives
I hope this helps
Dec 19, 2008 | eMachines T5274 Desktop PC
I beleive that this code is being displayed under the Device Status in the Properties window of the DVD Drive in Device Manager.
If it is so, you need to do some modifications with the Registry to resolve the issue and I am sure that the issue will be resolved with this.
However, since you had not specified the Operating System which is installed in the Notebook is Vista or XP.
However, I am providing the links which includes the steps for both Vista and XP to edit the registry to resolve the issue with Error Code 10 with the DVD Drive in your Notebook.
Removing Upper and Lower Filter in XP :
http://support.microsoft.com/kb/314060
You need to perform the steps listed under Advanced Troubleshooting to delete the Upper and Lower filters.
Removing Upper and Lower Filter in Vista :
http://support.microsoft.com/kb/929461/en-us
You need to perform the steps listed under Resolution in the link above.
You may not find both the Upper and Lower filters according to the instructions links provided above.
Delete the ones among the Upper filter or Lower filter or both which you find in the locations mentioned.
This should solve the issue...
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
