There is a green light in the picture on the screan when you are watching TV in the background. The color is not as bright either.
SOURCE: No picture, power light flashes green.
If you take the back cover off (and part of the front) you should be able to the cage that holds the lamp. Above that there is a small thermal fuse that occasionally goes out and causes this problem. Quick solution is to repalce with a normal 5amp fuse. Just clip it out and solder the new one in. I would use a pico fuse. Or invest in a replacement thermal fuse from a part store. Part number K5C117BC0003. Goodluck.
SOURCE: Panasonic lcd projection tv has first a pink spot
The pink spot and later green spots indicates the screen is at faulty,
The light engine is defective. The part is an entire assembly. It is about $650. You can get this parts from ebay.com or shopjimmy.com.
Hope this help in solving the problem..
We never saw a pink light just a green light on a section of the TV. It sometimeslooks like someone has a grren face but it is in only on little section of the screen.
