Question about Xante Ilumina Digital Color Press Printer
Stretched Printing of Photos and graphics
We have a Xante Illumina and use Macs with OS 10.5 Leopard. We've downloaded the latest driver, but we still have a problem with the output from certain programs, specifically InDesign, printing out stretched and oversized so that photos fill the page, or are larger than the page they were printed to. Anyone else have this or know of a fix?
  • Carl3 Dec 08, 2008
    Thanks! I'll give that a try tomorrow and let you know if that solved it!
    Carl
    Well, that must not be our problem. We're using Intel Macs, and when you "get info" and open "more info" it only shows the last time the application was opened. No checkbox. The files are not PC files either as they were generated on this machine with this software. Any more ideas? Thanks!
  • 24 Answers
Ok, the issue is most likely technical, but fixable with a mouse click.
your MAC, is most likely running a pc prossessor version.
this causes mis inter[pretation of pc based files and comes into play with CS3 programs..
go into the mac hard drive, and select the appliaction (in this case In Design) go the the info page, and click on "more info"...you should see a check box for "rosetta". check this box. and then print again, problem should be solved....is so, go into all the CS3 applications and do the same..check the rosetta box...good luck...
Posted on Dec 08, 2008
  • rooboy
    rooboy Dec 08, 2008
    hi Carl,
    sorry, it is the Intel powered MAC's that have this problem, please do this..
    go to the hard drive, and follow this trail..
    Applications
    Adobe Indesign CS3
    Adobe Indesign CS3
    More Info,
    when this opens, you should see a list of details, and just under the "color label" with all the colored dots, you should see the "rosetta" check option.
    check these links also, may help you understand the situation
    http://news.cnet.co.uk/desktops/0,390296...
    http://www.apple.com/rosetta/
    good luck, john
Xante accel-a-writer 4g for mac OSX 10.6
I haven't checked in a while. Xante told me when I called them that they were not planning to make updates past the current version of the 4G OS X drivers, as the machine was no longer in production. They said the driver should perform adequately on current versions of OS X even though it was not initially designed for them (as they did not exist when the driver was created).
I found this to be untrue in my case. The drivers did not allow me to print consistently from 10.5.8 on an Intel Mac Pro.
My solution was to activate the print server on an Xserve running the Tiger server version of OS X, install the Xante driver there (since it was designed to run on that version of the OS), and now my newer macs can use the printer without issue.
Apr 20, 2010 | Xante Accel-a-Writer 4G Laser Printer
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
Jan 06, 2010 | Apple Power Mac G5 Desktop
Patchy color printing, streaks and dull colors using Phaser 8200
I have the same exact problem. I just switched to a mac and the colors are awful. I tried from 3 different macs at work, trying different combinations of color profiles, settings, etc, and the colors always look completely off. Blues are magenta, bright red is a dull reddish, orange is completely brown. It looks like Xerox decided to not even try to make this aspect work with the Mac. This is on the latest Mac book Pro, running Snow Leopard, to a Xerox Phaser 8560 DN.
Jan 05, 2010 | Xerox Phaser 8200 Laser Printer
Xante Illumina runs very slow when printing on carbonless paper even for just black type. Could this be a sensor problem??
you need to check your settings, you may need to fool the machine..
on the webpage, or the front panel, select material type as plain.
set the weight setting as auto.
in the driver, make sure the setting is set to "printer Setting"
also in the driver check the selection for "black" instead of "colour"
hope this helps..
Mar 04, 2009 | Xante Ilumina Digital Color Press Printer
Mac OS 10.5 Leopard
you need to install Epson Easy Print too
Jan 15, 2009 | Epson Stylus Photo 2100 InkJet Printer
What is wrong with this Illumina???
I have been running this machine for 2 years. The only way I can run is too 1 printer media to plan - on Ilumina display panel 2 media weight to auto on Ilumina display panel - 3 When printing in printer dialog be sure set these options -  -printer features-insert option - set media type to Printer Setting
I have tried changing the media types as well and will not work for me- but setting to auto works. http://www.inkcoverage.com
Oct 14, 2008 | Xante Ilumina Digital Color Press Printer
Mac os x Snow Leopard
Apple's next major Mac OS X released, will focus solely on under-the-bonnet changes, the Mac maker has revealed. PowerPC-based machines might be left in the cold?
Apple is promising a version of Mac OS X that "dramatically" reduces the amount of storage space the operating system requires. Undoubtedly, some of that will come from the re-engineered core technologies, but it's hard to conclude that Snow Leopard's release will come not as a "universal" binary capable of running on both Intel and PowerPC processors, but as a single-platform product.
Universality has been handy in ensuring users can run the same installed code on both Intel- and PowerPC-based Macs without resorting to emulation. But just as Leopard lacks the ability to run Mac OS 9 apps - a feature present in previous Mac OS X releases - there will come a time when Apple drops Rosetta, its PowerPC emulation mechanism.
Early rumours concerning Snow Leopard suggested PowerPC support was to be dropped, though that was subsequently denied by Apple.
How can these two claims be reconciled? Only by Apple shipping native-only versions of Snow Leopard. Owners of Intel-based Macs will finally be free of all that redundant PowerPC code in the system software, freeing up space for, as Apple puts it, "their music and photos".
With any luck, Apple will finally allow users to readily remove unwanted languages from their system software, a process that can free up a fair bit of hard drive space too.
Apple won't be ditching support for universal binaries, or PowerPC Macs, because there, for now, too many of them out there. But if Snow Leopard's Grand Central technology does as promised and improves the OS' ability to work with multi-core CPUs, Intel-based Macs are going to shoot even further ahead of old G5 and G4 models.
Apple is also promising that Snow Leopard will offer more pervasive support for 64-bit computing, leading to the ability to support up to 16TB of memory, though the motherboard hardware to do this isn't there yet. In any case, limits to CPU memory controllers mean they don't physically support the full range of 64-bit memory addresses, only a subset.
Snow Leopard will also feature QuickTime X, a "streamlined" revamp of Apple's multimedia foundation, and OpenCL (Open Compute Library), a non-proprietary programming system for running complex code on a machine's graphic chip(s).
Oh, and it'll get Microsoft Exchange support too, in a bid to make Macs more business-friendly.
Aug 27, 2008 | Apple Mac OS X 10.4
Accel-a-writer 3g for leopard
Yes. If you need the driver here is the link. Just scroll down to operating system and choose Mac OS X. If this takes care of your problem please rate as fixed. Thanks.
http://www.xante.com/support/aw3g/
Apr 03, 2008 | Xante Accel-a-Writer Laser Printer
OS X Driver download
Here is the link for your driver. Just scroll down to driver section, choose Mac OS X and then click on the download arrow. Save it in a place you'll know where it is. If this fixes your problem please rate as fixed . Thanks.
http://www.xante.com/support/aw4g/
Apr 03, 2008 | Xante 4G Printer
277 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
