Question about Black & Decker BDCH100 Ceramic Compact Heater
Noisy B&D Ceramic Heater
I have a Black and Decker BDCH100 series ceramic heater that I purchased a couple of years ago but it's been rarely used. I turned it on this winter and found that it's very noisy. According to the User Manual, the heater is permanently lubricated and there doesn't seem to be a way to add lubrication. Are these heaters noisy by design or do I have a problem here? Many thanks in advance.
  • 625 Answers
Unit uses a sealed "muffin" fan.  you could check out grainger supply for a replacement fan.
Posted on Oct 15, 2007
I'm searching for a Honeywell HZ365 ceramic compact heater to purchase
this one is similar...
http://www.amazon.com/Honeywell-50250-S-99-97%25-Round-Purifier/dp/B00007E7RY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1354484907&sr=8-1-fkmr0&keywords=Honeywell+HZ365
Dec 02, 2012 | Honeywell HZ365 Ceramic Compact Heater
Panel won't hold a flame
this could have to do with the main gas feeds to the ceramic panels . they might be obstructed with a spider web or dirt,foriegn material etc.
easiest fix is to take a air compresser with a blow gun tip and blow out ant foriegn material or spider webs from the gas feed pipes to
the ceramic burners.
the gas feed pipes have large air induction holes that a small blow gun can fit its nozzle into to blow out the gas feed pipes without
having to disassemble them.
that is a big time & work saver.
I took my gas feed lines to the ceramic burners all apart, only to get out a spider web that i could have blown out with compressed air and saved myself 2 hours work.
anything inside the gas feed pipes to the ceramic burners will result in dark spots or the panels not staying lite, irratic burning
or no burning at all.
the gas needs to be able to get through unimpeded at proper flow and proper pressure for proper burning.
a spider web will mess up proper gas flow. some gas, but not enough gas will get through and ceramic wont burn well and might not hold a flame.
clean out the foriegn material from the ceramic gas feed lines.
Rare posibility,if the gas behind the ceramic element escapes around the edges of the ceramic, through a bad seal of the gasket,
this also will stop the ceramic from burning well.
mr heater is not made for easy diaassembly so try not to do more work than you have to.
use compressed air rather than taking mr heater all apart to clean out a gas feed pipe.
Mar 26, 2011 | Mr. Heater Big Buddy Heater
Holmes Heater HCH 4163 purchased 2 years ago & has seen only light duty. Upon turning heater on there is a severe electrical smell allthough heater appears to function normally; cord & heater do...
I think the warrenty on this heater is one year. If the heater housing and cord are not overheating then I would remove back panel and clean fiter and brush,vacumn,or use compressed air to clean motor and fan blades. It's possible that if you have not been using very much that it's just burning off debris and causing the smell. I hope this helps you. Thanks
Dec 20, 2010 | Holmes Products HCH4163 Ceramic Compact...
Do you sell replacement air filters for the BDCH100-301?
google your heater for local agent who should be able to supply parts
Aug 06, 2010 | Black & Decker BDCH200 Ceramic Compact...
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Black & Decker BDCH200C Ceramic Heater
There is a thermal fuse in this heater. A 133 deg. C fuse along with a bimetalic thermal cutout is attached to the top of the ceramic heater housing. This fuse is probably open, and is the most likely cause of your problem. This fuse is riveted in place, and is not easy to change.
Opening the heater case requires a special anti-tamper screwdriver. B&D don't want you inside this unit.
Apr 23, 2008 | Black & Decker BDCH200 Ceramic Compact...
Ceramic heaters
  1. I am thinking of purchasing thhz341bl heater to keep the pipes under mobile home warm for winter. Also can the osilitating be turned off?
Dec 10, 2007 | Honeywell (HZ-341BL) Ceramic Heater
CAUTION LIGHT only -- no Fan or Heat
According to the manual, the "Caution Light" means that the unit has overheated. They suggest running on a lesser setting, but you also may want to see if you can return the unit (if it is still under warranty).
Mar 31, 2007 | Black & Decker BDCH100 Ceramic Compact...
Black & Decker BDCH100 Ceramic Compact Heater Logo
139 people viewed this question
Top Black & Decker Heating & Cooling Experts
Paul Carew
Joshua Jennings
Rob
Rob
Are you a Black & Decker Heating and Cooling Expert? Answer questions, earn points and help others
