Question about Logitech Optical Keyboard & mouse (967283-0120)
Logictech Optical mouse & keyboard
I have been experiencing some jumping when the keyboard & mouse decided not to work at the same time. Had to manually sinc the Keyboard & then the mouse, both would work, but not at the same time. AFter 20 minutes, the problem seemd to have resolved itself, but there is still some jumping going on Help. Frustrated in Upstate NY
  • goofynana54 Jan 11, 2009
    How do you get the mouse to stop jumping around, AND sometimes I can't find the cursor-have to jiggle mouse
    Sergeant:
  • 311 Answers
Can you find any different mice and keyboards and test different combinations?
Jumping sounds like loose connectors, dirt in the mouse optics or particles in the keys...
Posted on Nov 06, 2017
CLUEPATEL
  • 138 Answers
SOURCE: connecting cordless optical logictech mouse
You should install all the necessary drivers! then it will work! moreover you should give your Mouse model so we can assist you further!
Posted on Dec 08, 2007
First, make sure you put the power on for your mouse.
Second, go to device manager and make sure your USB ports are working fine, if they're yellow and have a ? then you will need to install a new driver.
Posted on May 12, 2008
SOURCE: Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Posted on Dec 02, 2008
yooperbud
  • 8637 Answers
SOURCE: Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
ser71
  • 818 Answers
SOURCE: Logictech LX3 Optical Mous: Safe way to open to check
The screws are located under the mouse feet. However, doing this will void the warranty on your mouse.
Posted on Jul 02, 2009
When I press caps lock, no indication is given on the screen
depends on model ,logictech will make a noise when caps lock etc applied but no indication on screen.you can try the accessories on pc [tools]..EASE OF ACCESS this should help you
Nov 26, 2011 | Logitech Wireless Access Duo Optical...
Mouse is jumping
Dear sir,
plzz flllow this instruction for solved your mouse jumping problem once optical mice have problems with certain mousepads or mousing surfaces.
Perhaps changing your USB mouse to a PS/2 mouse or vise versa may also solve the issue.
Thanks For Your Time
Apr 02, 2010 | Logitech Cordless Mouse
Jul 02, 2009 | Logitech LX3 Optical Mouse
Wireless Optical Desktop 2000 keyboard problem
Did you install any software that came on a CD with the devices or did you just plug them in and let Windows try to download or install a driver automatically?
If you have not done so, I would install driver software from the CD it came with and make sure there is not any trick in the instructions to get it working correctly. Also did you check for a sync button on the keyboard anywhere? There could be a button you have to press on that as well as the mouse to get them working.
Mar 18, 2009 | Microsoft Wireless Optical Desktop Comfort...
Has anyone found a fix (short of getting rid of) for Logitech MX 600 Laser Mouse pointer erratic operation?? Seems to work OK on a Flat smooth surface, but jumps all over the place on any mouse pad I have...
  1. Mouse is not clean.
  2. Optical portion of mouse is blocked.
  3. Moisture or other material on finger.
Mouse is not clean Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Optical portion of mouse is blocked
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Moisture or other material on finger Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems If you've cleaned the mouse and continue to encounter issues and this mouse has worked in the past fine unfortunately your mouse is likely defective. One additional test that can be done to help determine if this is the case or not is to connect the mouse to another computer. Otherwise we suggest replacing the mouse.
Oct 24, 2008 | Computers & Internet
Connecting cordless optical logictech mouse
Apr 10, 2008 | Logitech LX7 Cordless Optical Mouse
Trust,,Optical USB Mouse MI-2900Z
Are you using an optical mouse? I suggest that you have to provide a mousepad since the laser of the mouse will have a hard time to read on its surface especially if you are using glossy surface of your table.
trust me,it works!! =)
Jan 25, 2008 | Computers & Internet
Dec 08, 2007 | Logitech LX5 Cordless Optical Mouse
Keyboard not working...
Have you pressed the connect button on the bottom (or side) of the keyboard. Having the mouse working means that all the rest of the kit is working, (as the reciever can connect to the mouse) if the keyboard will not connect (after pressing connect a few times)it seems that you have a dud transmitter in the keyboard, This does happen unfortunately (the oscilator crystal fails) if within warrantee try to get it replaced. Hope this helps
Aug 09, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Logitech Optical Keyboard & mouse (967283-0120) Logo
41 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
