Hi i formatted my sata hard drive and now my laptop will not reconignize it is there any thing i cando about this sata raid control drivers or something? gateway modle# MX8715
  • 1 more comment
  • mmooney22 Dec 06, 2008
    formatted in ntfs with another computer put it back in laptop and motherboard will not recognize the sata hd gateway said that they do not want you to install xp on there machines only vista its the main hd and its original and no i could not install os on it it said cannot find harddrive
    tatoo the hd to motherboard someone told me that but how do you fix the problem? how to tatoo hd to motherboard
    thanks...
  • Betty Wood
    Betty Wood May 11, 2010
    Is this a second hard drive or the main one? Did you install a OS back on the disk after you formatted it.
    Problem Solver:
  • 12 Answers
It is almost impossible to downgrade from Vista to XP unless you have the Business or Ultimate version of Vista.
From what I understand the first thing you should have done is If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first.
When you put the Win XP disk in to install and you get to the part that says "Press F6 if you need to install a third party SCSI or RAID driver"…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized. Install XP.
Let me know if this works for you....
Posted on Dec 06, 2008
  • 60 Answers
Hi whaT FORMAT DID YOU DO, FAT FAT 32 NT
EXPLAIN MORE
Posted on Dec 05, 2008
  • andy kissan Dec 06, 2008
    Hi again do you have an
    external connection for the hard drive or a different machine to check if this
    is the case.
    Years ago they used to
    tattoo a machine which meant you can only change 1-2 items e.g. (hard drive
    motherboards mem) which would not be recognized due to no tattoo on new equipment
    Then you need to tattoo all the new equipment, can you
    install the old hard drive then try to (will your laptop boot from usb ) if you
    can get it to recognized the hard drive from the usb will may be able to sort
    the other out later
    Cheers
Hard drive feel out and it dosent seem to reconise the drive know, it comes up with no bootable device
First of all, which do you want on the thing, Vista or XP?
Second, if you want XP, most likely you didn't install the Sata drivers for the OS disk from a floppy (must be downloaded in advance), and you should do that at the F6 prompt.
Third, do you have your boot order set to:
CDRom - 1st
Floppy - 2nd
Sata Boot Drive - 3rd
Fourth, do you have your boot order initially set the Boot Device Priority setting under the hard drive area to have the Sata you are using to boot as the first in boot order?
Fifth, clear up the raid issue for us, do you plan on using raid, or do you not. If not, then you must turn off the Raid controller in the Bios.
These are some common must-do things before we get too far
Oct 29, 2009 | Computers & Internet
I have a toshiba labtop with 2 hard disks working as raid. but I have formated my computer and now I lost the raid technology , so how can I restore it. I have the recovery CD and it should do it...
u will need a os setup disc which contains sata/raid support. u can make this setup disk. find out which sata/raid text mode drivers needed (i can't tell u which txt mode driver is needed as i don't know the model no. of the laptop)
find textmode driver needed for your model no. using google.
copy os setup disc(windows) on to the hard drive. use nlite to integrate textmode sata/raid driver. burn a bootable disc.
Recovery disc wont work as u have already formatted the drive.
Oct 06, 2009 | Office Equipment & Supplies
I want to reinstall my Y computer but the restore CD does not seem to work. So i tried a new XP cd, but that too could not work as it does not see the SATA hard disk installed. The Bios on the Tecra M9...
Hi, your Windows XP install CD doesn't have SATA drivers for the hard drive included, so it's not able to address your hard drive. You can't disable SATA in the BIOS to make it work since your hard drive is still SATA. You'll need to get a 3.5" floppy disk and drive if your laptop doesn't have one. They make external 3.5" USB floppy drives that will work.
1. download the SATA drivers for your laptop (iastor.sys and inf)
2. copy the drivers to your floppy disk (about 6-7 files)
3. plug the floppy drive into your laptop
4. boot to the Windows XP CD
5. as soon as the installation starts, it asks you to "Press F6 to specify RAID or controller drivers" - Press F6 now
6. When setup asks for it, point it to the floppy drive
7. Installation will continue and find your SATA hard drive
Ta-da! Rock on with your bad self.
May 18, 2009 | Toshiba Tecra M9-S5517X PC Notebook
Pavilion dv7 laptop driver problem BSOD
DV7 is not designed for XP, to get around the issue you may be able to change the BIOS setting for the SATA controller to work in IDE mode(depending on the BIOS) or you can use the XP installer option to install a SATA/RAID driver during the installer boot sequence. To offer you this I will need to know the model # and Serial # on the white sticker on the bottom of your laptop or the make and model of the SATA controller.
Try the Bios option and reply back with the requested info if it's not a viable option and I will see if there is an XP driver available for your controller.
Chris
May 15, 2009 | HP Pavilion dv7z Notebook
Updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Mar 01, 2009 | Computers & Internet
Hard drive
You need to use a Windows install disk, or the computer recovery disk.
At startup of new windows installation, chose new installation and then chose the option Format hard drive.
Note: the windows install disk must be bootable, Upgrade install disk (non bootable) does not have the format option.
Regards
Nov 05, 2008 | Toshiba Satellite A135-S4527 Notebook
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
Mar 10, 2008 | ASUS K8S-MX Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Philips freevents x52 laptop raid driver for F6
It's not easy to find info on this machine. I believe it has an Intel 945 chipset, and you can find the SATA driver here: http://www.intel.com/support/chipsets/sb/cs-015001.htm
Oct 06, 2007 | Computers & Internet
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
