Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
42" RCA Rear projection
TV won't turn on. Recd for free. How can I determine if the cost is worth fixing
    Genius:
  • 1,139 Answers
Hello Coloradolacy,
This set may cost you all of $5.00 to repair.
First I want you to unplug the set and look at the board containing the IHVT (called the flyback transformer by some) in the middle of the board you will see a heat sink and in the middle of the heat sink or close by you will see CP120, CP140, and CP150 one or all of these capacitors will appear to be puffy (bloated) with the top part pushed out. Replace all of the ones that look like this (puffy or bloated) That is your problem, the value of the CP150 is 2200uf 16dcv this one is usually the problem. It will cost you about 2.50 or less at radio shack.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
Monochrome picture
i would assume the red crt is bad or the red video amp is bad I would also assume you tried turning up the clor in the menu?? if it is the ube i would say no not worth fixing
Dec 02, 2009 | RCA P52937 52" Rear Projection Television
I OWN AN RCA 52INCH REAR PROJECTION SCREEN TV...WHEN I TURN IT ON...A GREEN LIGHT APPERARS AND BLINKS 3 TIMES AND STOP...WITH NO PICTURE OR NO SOUND....PLZ TELL ME WHATS THE PROBLEM?...IS IT WORTH...
24.95 the kit is called the CP150, CP114 and CP120 capacitors repair kit listedunder RCA reapair kits at www.tvrepairworld.com The kit contains the capacitors and detailed instructions on CD
Nov 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cost to repair an LCD tv screen
In today's electronics devices there isn't much to repair specially if the screen is damage. The cost of the repair might exceed the price of the LCD. A cheaper way to get it fix is to try to find a defective LCD(same model) with intact screen.
Sep 28, 2009 | RCA P52960 52" Rear Projection Television
I have the same issue with the turning OFF/ON. Help!!!
The tv power IC inverter board it dead.
The repair man will cost u $575 part & labor,it up to u the tv worth the repair or not.
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 42" Rear Projection TV
I have posted this before, and I believe that is fits this problem too, This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
61 in RCA Rear-Project color seperation
Your used TV is not worth much. Let us not fill our land fills with TV's. You may give it to a charitable oranganization (tax deduction) or local school that has an electronic course. Enjoy your new LCD you a great choice in type and brand.
May 04, 2008 | RCA P52926 52" Rear Projection Television
Convergance circuit board
you don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
