Question about ASUS P5VD2-MX SE Motherboard
I need some help please, my computer does wierd beeps
2 long beeps and 1 short
what does that mean?
I have recently faced the same problem the sound it makes is to tell you that there is fault with your ram so dont stress all you can do is open your pc take your ram out make sure you discharge yourself from any static clean the ram chips and make sure the ram slot is clean from dust put the ram back in your pc if it still does the same thing try doing the same thing a few times over if still no improvment then there could be fault with your ram chips or motherboard so get other ram that you now is working and test if the fault is with the board or the ram chips remmember the motherboard uses DDR 2.
Hope i have helped you if you got it fixed let me know by sending me a email to thefiend010@gmail.com
Posted on Dec 09, 2008
  • 341 Answers
Usualy means memory failure first slot.Try another stick in that slot and reboot. May also be motherboard problem.You haven't got one of those brass standoffs that you mount the motherboard in the wrong place where it's shorting the bottom of the board do you? Very common problem.
Posted on Dec 04, 2008
No display in motherboard help me my number is 7890360208
Do this motherboard beeping sound code first.
1. No beeps means short, no power and loose M.B. peripherals(VGA). (need to change Motherboard).
2. One beep means everything is working good.
3. Two beeps means CMOS error (need change bios rom ic).
4. Continuous beeps means memory not detected (try to clean slot and change memory).
5. One long beep, two short beeps means Videocard external loose or defective parts.
I hope this information will be helpful to you.
Regards
Jul 25, 2011 | Computers & Internet
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
I have mb-msi2000-815e pro ver1, it is constantly beeping. change the memories,agp,, but it still continues.what could be wrong/
1.Your first step is to look at the information about the meaning of the beeping codes. Beep codes are important and useful tools when troubleshooting booting issues. When you turn on your computer system, it is called POST (Power On Self Test).
2.No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
3.One beep is a normal POST. That means everything is fine.
Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
4.Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers.
Six, seven and eight beeps.
Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard.
Nine beeps mean the BIOS is bad. Replace the motherboard.
Ten beeps means the problem is in the CMOS. All chips need to be replaced.
5.Eleven beeps are related in the cache of the mother board and this means that the motherboard needs replaced.
One long and three short beeps mean that it is related to a loose memory chip. Try reseating it.
One long and eight short beeps means that the video cards needs reseated.
6.I hope that this list of beep codes will help settle the panic you feel when your computer is sick. If all fails, Then you inform me
Feb 21, 2011 | ASUS Intel 815E Chipset CUSL2-M...
The PC powers up, then starts beeping, one long beep and one short beep. The monitor tries to come on but shows the DVI with no signal; and the HDMI with no signal and the VGA with no signal and then the...
the beeps codes means there is a problem with a piece of hardware (RAM, or graphics card ,etc)
I need to know the BIOS manufacturer to interpret the code (phoenix or award or AMI)
for COMPAQ it means BIOS error --and will have to reload it from a recovery cd.
for IBM it means system board failure-- need new mobo--for a beep code of 1 long and 2 short most all mean graphics card problem.
If this was helpful, please indicate so, if not , comment back so we can resolve this issue
Dec 27, 2010 | HP Computers & Internet
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Blank screen long beep 2 short beeps at startup.
The 1 long 2 short beep code means a problem in the video circuitry and the laptop can't initialize the display. This is usually caused by failure of the integrated video chipset. Unfortunately, on a laptop you can't just open the case and install a new video card like you can on a desktop. You need to replace the mainboard. Replacements are available online. Here is one source found by a Google search. (I'm just using this as an example. I haven't dealt with this site.)
The 4 beep code means no memory detected when the computer started up. No surprise there since you had taken it out.
Apr 23, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
ASUS P5VD2-MX SE Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
