Question about Dell Latitude D800 Notebook
Keyboard replacement dell d800
Im looking for a page that will explain how to replace my keyboard.
    Problem Solver:
  • 10 Answers
Posted on Dec 04, 2008
Dell motherboard not coming on
For latitude there's not much to do. check the power adaptor/connecting pin --- if any problem. If not than u need to replace the board.
May 02, 2014 | Dell Latitude D800 Notebook
Dell latitude d800 not switching on ?
I may have addressed this question earlier. If your Dell shows absolutely no sign of life... no LEDs, no nothing and you know for certain the battery and/or power adapter is good then...
If you have access to a docking station (ANY Dell dock that will mate with the bottom connector on your D800), put the D800 in the dock and use the power button on the docking station.
If the laptop powers up, you may have a simply problem with the laptop "Press to turn on" button.
ABOVE THE LAPTOP KEYBOARD...
Use a small flat screwdriver blade to remove the Center Control Cover (just beneath the display/cover hinge and above the F1-F12 keys). Locate the cover's flat ribbon cable connector above the Page Up key. Pull off and carefully reinstall. Try the power button now. If it works, put everything back together. Otherwise seek profession help.
D800 screen goes very dim. Looks like it is off, but if I look really close I can see it is still on.
1st change screen inverter if same then u need to replace LCD thats it .. Thanks
Sep 14, 2010 | Dell Latitude D800 Notebook
I Have a Dell Latitude D800 and it's plugged into power. when i hit the start button it lights up a couple of lights on the keyboard, they go out after a couple of seconds and then nothing happens?
Is the battery charging? and is the power adaptor properly plugged in? If yes then it's probably a faulty PSU and you will need to phone DELL for a replacement/repair.
Sep 06, 2010 | Dell Latitude D800 Notebook
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Dell D800 Won't power up at all?
Bad news, this most likely indicates a problem in the charging circuit on the mainboard. To be sure, remove the battery and try again, if the same thing happens, then the problem is on the mainboard, if not, replace the battery. I have encountered this problem on an older Dell laptop before, removing the battery did not help and replacing the charger did not help. If the problem is on the mainboard, replacement is rarely practical. The cost of the board and the labor to replace it usually exceeds the cost of replacing the laptop.
Hopefully someone else has a better solution.
May 24, 2009 | Dell Latitude D800 Notebook
Hello, Im trying to find directions on how to replace my keyboard on my dell d800.
this is usually a snap on plate you can check if you can find the edge. usually you need to remove first the top plate in order to get to the keyboard, this is a plastic that you need to twist up a bit on both ends ( on the top of the F1- to - F12 commands) then once you have removed this top plate you can have acces to the keyboard, either it is screwed or fastened only
it is not difficult, cheers
Dec 04, 2008 | Dell Latitude D800 Notebook
Dell d 600 backspace key out/broken?
The key may pop back on but often you have to replace the keyboard. Fortunately the keyboard is easy to replace and they can be bought for less that $20 including shipping. Here is an example:
http://cgi.ebay.com/Dell-Laptop-8500-8600-D500-D800-D600-Keyboard-1M745_W0QQitemZ120258828907QQihZ002QQcategoryZ31568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
May 11, 2008 | Dell Latitude D600 Notebook
Dell Latitude D800 Notebook Logo
539 people viewed this question
Alun Cox
