Question about Teac DC-D2831 CD Shelf System
My mothers Teac DC-2831 skips when playing cds. We have used cd cleaning disc, and even compressed air. Nothing! What can we do? If we have to take it to a repair shop, can you give us one in the Los Angeles, CA area.
    Problem Solver:
My DC-2831 started doing the same thing -- and continued, despite repeated cleaning with a CD-player cleaning disc. Oddly, older CDs would play OK, but brand new ones -- commercial CDs, not homemade -- would promptly begin skipping or lock out altogether. Solution?
Unplug the system, lock the turntable stylus arm into place with the attached C-clamp, then carefully unscrew the back and side panels. Once the innards are exposed, gently lift out the CD-player and visually inspect it for hidden dust, pet dander, even fur can get inside there and gum up the works, and that's something NO CD-cleaning kit can ever reach.
Once you've inspected and cleaned the CD-player of all visible dust and dirt, carefully replace the player, make sure it's seated properly within the shell, then reattach the side and back panels in the exact reverse order as you removed them. THIS IS CRUCIAL: if you don't put the stereo back together in the exact reverse of how you took it apart, you'll have components off-kilter, screws that won't go back in (and leftover screws are a sure sign you're screwed it up!) and your CD-player will be even more temperamental than ever. Word to the wise.
If all this sounds too scary, then you'll have to either live with the crappy CD-playing performance, or get a new system. You can't replace the CD-player unless you buy an entire new system. WARNING: these all-in-one turntable systems are VERY RARE anymore, so don't get mad and kick your TEAC or toss it out or give it away on a whim. You'll play hell trying to find a replacement.
Hope this helps!
Posted on May 26, 2009
    Problem Solver:
  • 8 Answers
Some older players will do this using discs made from computer generated dics due to speed chages or disc burner . Try NERO burning set for slower burn alot better quality burn. If new disc check for scratchs horazanally( left to right not up an down.
Get a disc polisher.
Posted on Dec 11, 2008
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
The CD-P1250 skips while playing cds
There is no easy answer to this. I know that I have problems when I burn CDs in any format using my computers DVD burner. Fortunately I also have a regular CD burner which seems to do a much better job.
It may also be the CD player needs to be cleaned, seems that MP3 capable CD players are more sensitive when playing MP3 discs as opposed to regular CDs. There is really no other format that is widely supported (other than WMA) that will give you the capacity of a MP3.
May 24, 2010 | Teac CD-P1250 CD Player
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
I have the CD Home Music System. Lately when I
The first thing to try is use a CD lens cleaning disc. The disc has a fine brush that will sweep contaminants away from the lens on the optical pickup in the drive. Also, depending on the design of your system, you may be able to use a clean and dry q-tip or a can of air duster to clean the pickup. Dust contamination is the most likely suspect for your problem and cleaning the drive is the first step you should take before going further. Best of luck!
Dec 22, 2009 | Audio Players & Recorders
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
TEAC MC D90
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Aug 18, 2008 | Teac DC-D2831 CD Shelf System
Teac DC-D2831 CD Shelf System Logo
245 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
