Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer rear projection SD-P452 Blinks on/off really fast
I have a Pioneer rear projection TV model SD-P452. In the last few months it has started blinking (the picture an audio) like it is being cut off and back on really fast. The longer it is on the more it seems to do this.
  • 1 more comment
  •  Tina Keeling
    Tina Keeling Dec 04, 2008
    where can i get a manual on how to take out the main board to have it checked. it is a pioneer rear projection sd-p452
    thanks
  •  Tina Keeling
    Tina Keeling Dec 05, 2008
    i found a manual, but need to find where parts can be bought for this old pioneer projection tv
  •  Tina Keeling
    where can i order parts for a pioneer projection ytc (old) sd-p4452 model
  • 1,183 Answers
HI,
you can order parts directly from pioneer, here is the link
http://parts.pioneerelectronics.com/
alternate places to source the parts are from
http://www.partstore.com/Sitemap/pioneer-tv-parts.aspx
http://www.shopjimmy.com/searchparts.cfm?make=Pioneer
Thanks
Proton
Posted on Dec 05, 2008
  • 2,336 Answers
Would you be able to repair it?
The reason i'm asking you, is because there are dry/crystalized solder joints in the power supply/Horizontal sections of the TV if the audio and video are affected. These faulty solder joints can be found around components that generate high heat when functional, resistors, transistors, ICs and power regulators. You should use a magnification aid of 4X or better to see the hairline solder cracks.
Let me know if you require further assistance.
Posted on Dec 04, 2008
    Sergeant:
  • 217 Answers
The electrical component on the main board is getting heated up after sometime and it starts doing this .remove the board and get it checked and replace the component which is faulty.to avoid further problems.
Rainbow colours on the screen
The projector is starting to go out in it. Depending on your financial situation, you can take it to a shop to have it looked at, or replace the TV. Depending on how long this has been happening, the Pioneer projectors usually last about 100 hours once this happens before they burn out completely.
Apr 30, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer Model SD-P4571 Problems?
It could be because of where you live.
Hi humidity, High temperatures where you live, etc.
Try placing a cooling source next to it, like a small portable air conditioner and even a fan.
Also, please try installing a GFCI outlet AND plug a surge protection outlet strip for all components and tv.
Any spike in your electric circuit, for example, a refrigerator starting, a furnace running etc. can cause the tv to turn off.
Regards,
Yalmer
Mar 13, 2008 | Televison & Video
Tv picture blinks on and off
Sounds like a cracked solder joint. I would check the flyback mounts , then the horizontal and verticle deflection ciruit componnents for cracked solder joints.
Jan 04, 2008 | Televison & Video
Pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Dec 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Aug 13, 2006 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
