Question about Olympus Camedia C-755 Ultra Zoom Digital Camera
Olympus c755 The settings are lost after I turn the camera off. Example full auto focus reverts to the off state, When the camera is turned back on I have to reprogram all settings.
  • 114 Answers
Well the battery can´t be replaced by the user, the battery it´s on the mainboard and is weldded to the mainboard, i don´t know if u can find this type of batteries on the shops. it´s a kind of watch battery but it´s recharchable. good luck
Posted on Feb 24, 2007
    Novelist:
  • 107 Answers
Your backup battery has gone dead. Check your manual to see if it is replaceable, or if it needs to be replaced by a repair shop. I have a C-750 on my bench now in for repair, and I do not see a customer-replaceable backup battery. I do not know if this applies to the C-755, but the C-750 requires disassembly to replace this cell. David Millier Advance Camera Repair
MY OLYMPUS DIGITAL CAMERA FE-230 IS OUT OF FOCUS? PICTURES TAKEN ARE ALL BLURRED.
Try one of these tips:
>Hold your camera steady using both hands
>Hold your breath just before you take a hand-held shot
>Use a tripod, or a set your camera on a steady surface
>Set your camera's self-timer
Set the dial mode to auto ;
Turn off macro mode;
Turn on the camera's flash.
At the link below you will be able to download the instruction manual for Olympus FE-230 Digital Camera:
Click HERE
Jul 26, 2011 | Olympus Cameras
Olympus E-510 Flash & Auto-Focus Problems
Sounds like the main circuit board has got problems. If its under warranty use the manufacturer. But if not a camear store should be able to provide a quote. I admit that the repair will be about 150-180 because of the time involved in replacing the board and possibly the flash unit.
But quotes before bankruptcy..
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Olympus EVOLT E-510 Body Only Digital...
Flash-Off Problem
Do you have the camera in the auto mode?
Did you check to make sure that the auto focus is not in the manual mode when the flash is turned off?
If the above does not comply, call the tech support for the camera.
There is also a possibity that there is a defect, or that the flash is part of the auto focus function.
Jerry G.
Sep 15, 2008 | Olympus ? Stylus 500 Digital Camera
Olympus C-765 does not focus
Dear Benjamin,
I also own an olympus c765 and was wondering how to use the manual focus option when I came across your post. Actually I have been wondering whether manual focus is of any use in an olympus c765 because the manual does not talk anything about it.
However, I just found out that there is a way of activating/deactivating manual focus. Here it goes:
1. Turn the camera on
2. Switch to any mode - portrait/landscape etc
3. Press and hold the 'OK' button on the centre for a second until you see a MF/AF option on the screen
4. Switch to MF and focus on any subject by pressing the up/down keys.
Most likely, your camera has been turned to Manual Focus option, which is why it is not focussing any more. Follow the steps above and turn it back to Auto Focus option and let me know if your problem gets solved.
Regards
Aug 30, 2008 | Olympus Camedia C-765 Digital Camera
My Olympus 740 digital camera does not auto focus any more. I can make it focus for the most part by zooming in, but is there anything I can do to make it start up focused? I had another Olympus camera...
Take it off manual focus? There may be an "all reset" option in one of the menus that makes the camera factory default whenever its turned on, usually this is full auto mode. If the camera will only focus when the zoom is used, there may be a secondary lens inside the lens barrel that is not moving as it should. Time to service it if that is the case.
Jul 07, 2008 | Olympus Cameras
Camera gose back to defult setting
http://www.fixya.com/support/t161213-replacement_internal_battery
Just found the above on the same web site. This looks like the solution..
Dec 01, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Auto Focus Problem
Way to check settings is to take the batteries out for a while, it should revert to factory default settings. I tell a lot of People to try this, it works an amazing number of times. Auto focus looks for vertical lines, what are You shooting at? Try rotating the camera 90 degrees, if it locks better,Bingo. Subjects without much contrast are hard to lock focus on
Sep 12, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
"Battery Save"
This setting helps to conserve battery power by restricting several functions: The back LCD monitor cannot be turned on while in a shooting mode, it will turn on while in the Play mode. Full-Time AF (auto focus) cannot be used and the viewfinder will turn off after the 30 sec. without use.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
"Battery Save"
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Olympus Camedia C-755 Ultra Zoom Digital Camera Logo
241 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
