Question about Panasonic KX-TG1033S Cordless Phone
Clear missed calls message
How do I clear the missed calls message? There are a number of calls where no message is left and so there is nothing to erase and the calls keep adding up making it difficult to know whether there is a new missed call. I have the four hand set model -- 1034
  • 3 Answers
You can try this, it worked for us.
Press the key that says CID (Caller ID) to view every missed called telephone number. They disappeared, but we had to do each handset. Hope that works for you.
Posted on Mar 12, 2009
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
Tip
Ericsson CODES DESCRIPTIONS
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
Shortcuts:
Save a Missed Call into your phone directory Scroll to "Missed Call", press "Yes" to display the required number. Press any number (i.e. 0 to 9), then press "clear" once to clear that number, then press & hold "<" until you see "Store". Press "Yes"
Hide your number when calling when you don't want the other party to know your number) After dialling the required number & before pressing "Yes", press ">" twice to choose "Hide Id?" & then press "Yes". Also works for pre-programmed & last dialled numbers just press "No" & wait for the number to appear on the screen first then follow same procedure
Check you battery level when phone is off Press "No" quickly one time & wait for the battery meter to show up!
Save a number into your phone memory (not SIM card) Follow normal procedures to store a phone number. When prompted to set a storage position, press "#" once & key in desired location, or press "#" twice for next available position
Call a phone number from SMS message You can call from within a SMS message if the phone number is written in it. Just scroll the message until the phone number appears on the display, then press "Yes" to call
on Aug 30, 2009 | Nokia 9500 Communicator
Kx-tga820b how to clear "new voice mail"
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Apr 09, 2014 | Panasonic Lands Phones
I can't clear 1 missed call message from the screen of my tesco AWB001 cordless phone
Press the top right button marked with a right arrow, then repeatedly press the top left button marked with a left arrow. This displays all the missed call numbers. When you've seen them all, press INT/ESC and put the phone down. It's horrible!
Nov 02, 2012 | Cell Phones
HOW DO YOU CLEAR RECENT CALL AND MESSAGES
Hi trsampson,
To clear recent calls, here are the steps to follow:
1. Go to the 'Menu' option.
2. Scroll, till you get to call register.
3. Select it, then scroll to 'delete recent call list'.
4. After you have selected it, you would be provided with the options to delete,
i. 'All calls', selecting it would entirely wipe off your entire call log.
ii. 'Missed call', selecting it would delete your entire missed call on the call log.
iii. 'Received calls', selecting this deletes all your received calls.
iv. 'Dialled calls', selecting this deletes all your dialled calls on d log.
You could also perform selective deleting. You might want to delete a/some paticular number(s) that is on the log, not the entire log.
To effect this, after step 2 above, you can scroll to either of 'missed calls', 'received calls', or 'dialled calls'. Select the one which pertains to the number you want to delete, scroll through till you get to the particular number(s), select 'options', scroll till you get to 'delete', then select delete, and the number is deleted. Do it for as many numbers as you want to be deleted.
To clear messages,
1. Select the menu option, scroll till you get to 'messages'.
2. Select 'messages', scroll for either 'inbox' or 'sent messages'.
3. Select whichever you want to delete from, scroll to the particular message, and select 'options', sroll again, and select 'delete'.
Hope that helped?
Success.
May 09, 2011 | Motorola Cell Phones
The number 27 is on the display all the time
This is the number of missed calls you have.
To clear missed calls you need to press down arrow (centre 4 way keypad) 27 times with a short pause to clear the missed call history.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Panasonic KX-TGA101S Cordless Handset
How to clear the recent log phone numbers
go to call menu and press options and there will be an option that says clear
Feb 16, 2010 | Samsung SGH-a737 Cellular Phone
I am showing a missed call that will not clear. I was on the web when a call came in. The phone laggedout to the point I had to pop the bat to clear it. When the phone came back on it showed the missed...
Cause:-
The messages database or database state are corrupt.
Resolution:-
The following steps may resolve this issue.
a) Perform a hard reset of the BlackBerry smartphone:-
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
b) Clear all messages databases: SMS, MMS, email messages, and Phone call logs.
To clear individual databases from the BlackBerry smartphone, complete the following:-
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Backup and Restore and then click Advanced.
4) From the list of Device Databases, select the appropriate database. For example, to clear email messages select Messages.
5) Click Clear.
6) In the Warning window, click OK.
7) Click Refresh to confirm that the database has been cleared.
c) Select the Wipe Handheld option to delete all the data from your BlackBerry smartphone.
To clear the application databases from the BlackBerry smartphone, complete the following steps:-
2) Open BlackBerry Desktop Manager, and then type the password for the BlackBerry smartphone.
3) Double-click Backup and Restore, and then click Advanced.
4) Press and hold the Shift key while selecting all the databases in the Handheld Databases list box.
5) Click Clear.
6) Click OK on the Warning window. All application databases on the BlackBerry smartphone are erased.
I hope I was able to help you.
Oct 09, 2009 | RIM BlackBerry Pearl 8100
How to clear message symbol and flashing green alert
A: The envelope means that you have received unanswered calls in the Caller ID Call Log. To remove the Envelope press the "CALLER" button to review the missed call telephone numbers by scrolling with the ARROW buttons
May 11, 2009 | Lands Phones
Panasonic KX-T7433 Message Light
If there is no message and you just want to clear the light, press the message button on the bottom panel of the phone and then the button at the top under the display screen that lines up with "clear". That will turn off the message light.
Mar 17, 2009 | Panasonic KX-T7433B Corded Phone
Panasonic KX-TG1033S Cordless Phone Logo
1,718 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
