Question about NetGear DG834G Router
Connecting two laptops using Netgear 834G
Hi there, I am quite new to the routers and their configuration. Can any one tells me steps to connect two laptops using Netgear 834G router please? I am using Talk Talk Broadband. I will appreciate if you could help me out on this problem soon.
    President:
  • 2,961 Answers
If its just a router and not a modem router, go into the routers settings and make sure DHCP is enabled to give each pc an automatic IP address and ensure wireless is enabled if using wireless adapters. Next go to the properties of your network card and on the TCP/IP select properties and ensure obtain IP address automatically is ticked. You must also set up using the XP network wizard and ensure file and printer sharing is set up through both pc's.
Posted on Feb 08, 2007
I need to reconfigure my router
download the latest wireless drivers for your computer on another pc/laptop and reinstall it on your new windows 7 box. try and reconnect to your wifi
Feb 20, 2012 | NetGear WNR2000 Wireless Router
Netgear router N 300 cannot connect to the internet using laptop
There are many router related settings on NETGEAR wireless router and if these are not configured properly, then issues such as router not connecting to Internet might come up. All NETGEAR wireless router users facing router not connecting to Internet are suggested to verify the router related settings such as access points and reconfigure them if required. Users are also advised to check the firewall settings on the system and ensure that they are not blocking the connection.
Jul 03, 2011 | Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
At work we have a LAN connection, can a Netgear 834g router be used as a wireless access point by plugging the LAN into one of the ports, (using it as a port switch?)
yes you can use as a wireless access point by plugging lan cable in to the yellow coloured port on your netgear not any of ports, have a good day....
Feb 01, 2011 | NetGear DG834G Router
I have a Netgear router model 834G purchased in the UK. Will it connect to the french telephone network on ADSL without any problems?
yes you can use it with it.Just you need to configure your router as your french telephone ADSL settings.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 23, 2010 | NetGear DG834G Router
Can't get connection through router to internet
Hi,i beleive you have checked with your service providor as to what type of IP configurations is required.That is if you have a static Public IP or multiple IPs.If you have already checked the router configurations make sure your PC or laptop is configured accordingly.That is you have to configure your PC or laptop in a DHCP way.You can go to control panel from Start option and then go to network wizard,you will have 2 options,the 1st one would be assigning a static IP and then the next one would be Obtain an IP automatically.Click on the radio button there.Restart your comp and the router.You should be good to go.
For any further assistance please revert.
Apr 09, 2009 | NetGear WGR614 Wireless Router
Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
Oct 28, 2008 | NetGear DG834G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Router 'IP' Problem
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
If the problem is still not solve call supportrix to avail 1 time free tech support. use SUPPORTCALL as you promocode
Jun 09, 2008 | NetGear WGR614 Wireless Router
NETGEAR DG 834G ROUTER
Could you give me some overview of the topology of the network your trying to install the router on? (How it's all connected, and the ip addresses of the machines and other routers on the network (if any)) ?
Nov 29, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
103 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
