Lost manual which channel do i connect satelite box to for hd
Cannot find connectoin or channel for hd
Many thx for looking at my post
i have a sony wireless home cinema system and i am having problems setting this up, the sound is not very loud and even much so on the wireless speakers.
you have to put your ears right up to the wireless speakers to hear them, i have connected it to my plasma with a hd cable and optical lead, and as far as i am aware i have connected everything else up correctly
very much app any help at all as i am sure this is a good setup
thx andy
Posted on Jan 04, 2010
Found my manual and found out which channel to use
Posted on Dec 05, 2008
I just bought a progressive scan Tv and can't get it to srtup to any channel it just stays on channel 3 mono
Progressive scan has nothing to do with your tuning, it refers to the scan lines in laying the picture on the screen...ie. progressive scan versus interlaced scan.
to program TV channels you will need to go into the menu to do that either automatically or manually. If you have a cable or satelite box connected to unit, that may explain why it programs to only ch 3.
If using cable or satelite box I highly recommend use of Either HDMI cable or composite cables.
Apr 07, 2014 | Televison & Video
Satelite Dish
please tell the model number please.
reply.
Oct 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
I have did the auto scan and the tv screen is still blank. i need some answers asap please!!!!!!!!!!
does a DVD player work on the unit?
if so, be sure you have good connections of your input cables (and you know these connector cables to be good), then see if you can manually program channel 3, or any other channels programmed manually. I suggest channel 3 in case you are using satelite or cable box. Then turn the cable or satelite box & see if you get reception on channel 3.
Apr 01, 2014 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
No solution found on your site. My 62" Toshiba DLP makes an extremely loud chopping noise when on HD channels using a satelite service. (Happened on Dish and Suddenlink) No sound except for the chopping....
Have you contacted your satelite provider? Have you any other HD sources to try, A Playstation 3, a blue-ray disc player or even using the TV's terrestrial HD tuning system can tell you if its the TV or the Satelite.
michtech
Feb 18, 2009 | Toshiba 62HM95 62" HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Ami - speed touch router
Try changing channels on your wireless router. Routers have configuration page where you can change the channel. Refer to your user manual on how to change the channel on the device.
You may also try moving the router to a different location or maybe on a higher location. To avoid interference.
Oct 18, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
Please scan channels
try hitting the input button or go to channel 3. the sat box can only output to channel 3 or 4 or if using Dish network try channel 66 or what ever the channel it outputs. it also can output via video cables so check each video setting on the set. make sure the box is on first.
Dec 23, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
51 people viewed this question
 Grubhead
Grubhead
