Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
Could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Posted on Dec 04, 2008
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Kind Regards
JEDEMEYER1
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Spin cycle not working
When you say the spin cycle is not working do you mean that nothing works in the spin cycle. For example: Does the drum move or does it move and but the water isn't drained out?
Jun 19, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Nexxt Washer Problem
timer not sending signal, or bad transmission
May 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Tub won't empty[error 4]
There should be a filter located at the bottom front right of washer behind flap
Unscrew anti-clockwise to remove and clean.
Mar 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Will not spin out water
Sure its not pump you can hear? your motor carbon brushes may need replacing
Feb 11, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Clothes too wet upon cycle completion...
Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
Jan 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
410 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
