Does change drum mean change toner on a brother mfc 7820n?
  • 37 Answers
No it does not. The toner and drum are seperate in this machine. The drum part number is DR350. The drum is pictured below.does change drum mean change - 10366503.jpg&size=4&dhm=8e1cc2c5&hl=en&mode=1
Posted on Dec 04, 2008
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, etc....it still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
My brother MFC-7820N printer was printing very light so I took out the toner shook it from side to side now it is printing very dark with shadow images of the text
You might have gotten toner on the corona, take the toner/drum unit out there is a blue knob. slide that a couple of times and try it.
Aug 30, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC 7820N Printed paper has toner ink layered on paper
you can remove the toner and drum from the machine, slide the tab back and forth about 20 times then blow in the slot. when you put it back in the machine if the problem keeps happening it would be a problem with the toner cartridge and it would need to be replaced
the reason this happens to toner cartridges is because the rubber roller tarts to wear out.
Mar 05, 2010 | Brother MFC-7820N All-In-One Laser Printer
How do you reset the toner low LCD message when you change toner cartridge?
I believe you mean, DRUM Reset.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Jan 12, 2010 | Brother MFC-7820N Printer
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Apr 22, 2009 | Brother MFC-7820N Laser Printer
Brother 7820N, printing image repeats?
have you tried changing the drum unit for a brother oem unoit and oem toner? generic toner and drum will always mess the machine up!!!!!!! good luck brother sr tech
Dec 22, 2008 | Brother MFC-7820N Printer
261 people viewed this question
k24674
