Hi I have a problem with a HP A708N. When I try to boot the computer windows does not open,there is a window that says "Entering Power Saving Mode" which stays on for a few minutes or so. It also pops up when I shut the computer down for a few seconds. Anybody have any ideas. Thanks
  • 519 Answers
Have you tried disabling power saving features in the control panel?
Posted on Dec 04, 2008
I open my computer today but suddenly the monitor says " entering power save mode" and its stuck there. ive tried to do simple ways to fix but still nothing. can someone help me? im using windows 7
Switch off and remove the power cable then put in the power cable again and switch on again...try to disable the power saving mode once it is on.
Apr 05, 2013 | Dell Computers & Internet
Need recovery disk for hp mini 2140
you could try this if it helps
There are two ways to access Roxio BackOn Track to recovery the computer, either through the boot menu, or through the Windows Start menu.
    You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored.
    1. Press the power button to turn on the HP Mini.
    2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.
    If you can access Windows, in addition to restoring your computer to a previous working state, you use other options, such as Disaster Recovery.
    1. Click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track
    Hope this helps you
Aug 19, 2011 | HP Mini 2140 Notebook
When i turn on it goes start to pc entering power saving mode
Are you sure it isn't the monitor entering powersave mode?
An unhooked monitor (especially flatscreen DELLs ) will go into powersave mode if it isn't getting a signal but is getting power.
First unplug and then replug your monitor. Both ends of the cord, the end in the back of the monitor (if it comes out at all) and the end that plugs into the computer.(unplug it from the wall first)
Reboot computer.
If that fails...(and you do have a video card)
Unplug everything from the computer, open the box, ground yourself by touching the metal frame of the computer case and reseat your video may have to undo one screw to get it out.
DON'T drop the screw into the case!
Put it all back together and try again.
If that all fails Boot Windows (windows right?) into safe mode and change the power settings for the monitor...perhaps something got changed or broken by an update.
If that fails....
Get Linux.
Aug 17, 2011 | Gateway 505GR PC Desktop
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
Have hp pavilion a340n that won't start, screen says "WARNING" PC entering power saving mode and then goes blank. the computer never boots up.
hi mylesj880,
Press del. or f8 to boot to Bios there should be an option for you to remove power saving mode. If none then you probably need to update the bios be careful when updating bioses.
Hope it helps. Feel free to ask
Sep 02, 2010 | Computers & Internet
When I log onto my computer it will not run any programs at all. The most it will do is open a window and say it's loading but it never actually does. I can't even get into the recovery program because it...
insert Windows XP cd and use recovery console, or try entering emergency mode by pressing F8 while computer boots.
Leave rate if I helped you, thanks!!
May 09, 2010 | HP Computers & Internet
Monitor displays "warning pc entering power saving mode
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Computers & Internet Logo
David Payne
David Payne
