29H-FD1F sharp TV the picture has extended . is r=there any manufactory reset?
Pls help me what the value of resistor 601 model 21v-fw600s sharp tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 21, 2016 | Sharp 29h-fx1a Flat Screen Multisystem TV
Sharp LC-70LE745U will not power on. Blink code is 2 long, 2 short. Tried the force power key sequence and the factory reset, but no joy!
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Nov 20, 2014 | Sharp Lc-70le745u
Sharp LCD tv has sound and no picture, will a reset work?
Do this first. Shine a flashlite on the screen to see of you can see a picture with the TV on and listening to a program. If you CAN see a picture the backlight drivers are bad If no picture the T-con board is bad. You can get parts from here :www.shopjimmy.com
Jun 25, 2014 | Sharp LC-32SB24U 32 in. LCD TV
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Green solarization effect in picture - Sharp LCD TV
I have had the same problem this week on my Sharp 32" LCD TV. I'm told that it is a 'contact' problem that Sharp are aware of. A screw has been modified to correct this. My TV was repaired on-site & took about 15 minutes to replace the faulty part. I have an extended warrenty (thankfully) so can't give you a price for the repair - sorry. Best of luck
Aug 19, 2009 | Televison & Video
Help
try going to display properties and extending the desktop to the Sharp
http://www.aa1consulting.com
Jul 26, 2009 | Computers & Internet
Flicker
I have the same problem when going to dark scenes from a bright scene or during channel changes. Sharp sent a tech under warranty and he installed new software to no avail. He called sharp tech support and they suggested turning on opc. The TV works fine but you must adjust sharpness and contrast to achieve an acceptable picture. I paid $868.00 for the set a Sam's club and will buy an extended warranty. I will not buy another sharp. My 40" sony works perfectly.
Oct 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
try cleaning mirror and lens inside
Dec 16, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Open Questions:
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
