SOURCE: instrument cluster removal 2001 buick century
You have to remove the dash but it is VERY simple to do.
Remove the fuseblock cover on the end of the dash on the passenger's side.
Once removed, remove the screw holding on the end of the dash.
Now, next to the glove box, to the right, remove the one screw on the bottom. Then remove this panel by pulling it out (it will now be held on by two clips at the top.)
Now, looking at the temperature control cover, remove the two screws from the bottom of this. Pull it off. It also is held on by two clips.
Now, below the steering wheel, remove the one screw from this panel (on the right). On the left there is a "plug" holding it in place, Pop out this plug. I think there are a couple of clips now holding this on at the top.
Now that you have all of that pulled out, pop the dash out. At worse, it is held in with clips.
Now that you have this out, there are four screws holding in the instrument panel. Take out these four screws. You will find one electrical cable connected to the cluster. Pop that off of the cluster and you now have the entire instrument cluster in your hands.
I've had to take mine out to figure out why my gear indicator/odomiter would not illuminate (Buick told me it was a light). I can see where this encased LED has a short (black mark). It is soldered onto the board. Looks like I have to purchase a repaired board.
I hope this helps.
SOURCE: instrument cluster 2001 buick century
It comes off from the front. Open the front passenger side door and remove the fuse panel access door on the right hand side of the dash. There`s 1 screw to remove frome the dash cover and then pull the cover off. It`s easiest to work the top out and then lift up and out. Then there are 4 screws that hold the instrument cluster in place, remove them and pull it out andf you`ll have access to the bulbs.
Once you do it you`ll find you can pull the ****** out in 5 or 10 minutes.
SOURCE: light showing odometer and what gear transmission
The cluster will have to be sent out for repairs or exchange by a dealer or see Model Electronics.
SOURCE: Instrument Cluster Panel out on 2001 buick century
2001 Century just hit 40,000 miles and the engine light has come on. Im wondering if this is an automatic when the car trips at 40K- for a check up or whatever GM wants your money for.
ps - from '89 to 2008 I had been driving Nissans, Toyotas and Hondas - Im driving this car only because I gave my Toyata Rav4 to my daughter and got this Buick from my elderly mother as she no longer drives. Its is amazing what a piece of **** this car is compared to what Im use to. At 40,000 miles you start having the engine light come on - amazing!
SOURCE: blower motor fan works on high setting only
The resistors are located in the firewall just above the blower motor. they have a heavier gadge wire going to it. As for the water if it is not antifreeze then you have a leak in your cowl area by the lower windshield. I ran in to this problem on several gm cars such as yours it can be deficult to find good luck
Testimonial: "Iccjester, thanks for the information it was very helpful much appreciation Mike S 1999 Buick Century"
