Line error COM.E-7
I have sent a fax twice but as soon as the 2nd (llast) page has gone through I get the message Line error and a Transaction Report is printed which states under the heading Note: COM.E-7 and the second time it was: COM.E-2.
Can you advise? Has my fax gone through?
Carol
Fax machine: Sharp UX-B30
  • 82 Answers
SOURCE: SHARP UX B700 TRANSMISSION REPORT
Does your machine show anything on the confirmation report like fax number,duration, pages sent, etc. or is the image just not being printed. If you have properly programed machine to show image on the confirmation report. I don't see anything that will cause that except your origianls may not right side up/down.
Thanks,
Mikey
Posted on Apr 03, 2008
leroyal
  • 2120 Answers
SOURCE: only transaction report printing no
Somewhere in your fax defaults menus you should see "enable image".
However, some brands don't have that option available.
Posted on Sep 12, 2008
  • 3422 Answers
SOURCE: My Sharp fax machine model
Unplug the fax machine from the power outlet and allow it to reset for 30min. Then plug it back in to the power outlet. If this does not solve the problem, thencheck if the phone line between the fax machine and the wall is 'OK'.
Let me know the result
Posted on Oct 01, 2008
checkitright
  • 1362 Answers
SOURCE: I would like to setup my fax
free manual just register
http://www.nodevice.com/manual/sharp/UXB30_SM_GBpdf/get42962.html
Posted on Oct 31, 2008
slipnoman
  • 53 Answers
SOURCE: NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Posted on Jan 09, 2009
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
How would i get the fax report
from the user manual:
The default fax confirmation setting is Every Error. This means that your
HP Officejet prints a report only if there is a problem with sending or receiving a fax. A confirmation message indicating whether an item was successfully sent appears briefly on the front panel display after each transaction. To have a confirmation printed for every fax, follow these instructions.
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press direction right button until Every Fax appears in the second line of the display, and then press OK.
The HP Officejet will print a confirmation report every time you send a fax informing you whether the fax was sent successfully or not.
Enjoy
Christopher
May 21, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Sharp FO-4400 Manual
Setting 05: TRANSACTION REPORT PRINT SELECTION
This sets the condition for printing out a Transaction Report. Enter a number
from 1 to 5 as follows:
1 (ERROR/TIMER MEMORY): A report will be printed after an error, timer
operation, or memory operation.
2 (SEND ONLY) A report will be printed only after a transmission
3 (ALWAYS PRINTS) A report will be printed after each
transmission, reception, or error
4 (NEVER PRINTS) A report will never be printed.
5 (ERROR ONLY) A report will be printed only after an error occurs
Oct 20, 2011 | Sharp Office Equipment & Supplies
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
Hello! I work in an office and we use the Kyocera KM2050 and are trying to figure out how to have a confirmation page print after a fax is sent just so we know it was delivered successfully. Thank you!
1 Press the System Menu key.
2 Press the down arrow key to select Fax Default.
3 Press the Enter key.
4 Press the arrow down key to select Print Report.
5 Press the Enter key.
6 Press the arrow down key to select TX Transaction.
7 Press the Enter key.
8 Press the arrow down key to select when you want the report to print out.
The asterisk (*) in the message display indicates the current setting.
9 Press the Enter key. The setting for that report is complete.
> If you want to continue the setting procedure for other reports, repeat steps 6 - 9.
> If you want to perform other setting procedures, select End and then press the Enter key.
> If you are finished making settings, press the Reset key. The operation panel will return to the
initial mode settings.
This information can be found on page 7-2 of the Fax System Operation Guide which can be down loaded from Kyocera's website.
Jan 06, 2011 | Kyocera Mita KM-2050 Printer
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
FAx Error
I understand that you are receiving the error "fax not sent" and the transaction report Error 389*. while sending fax.
The issue that you are experiencing is due to communication, however please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=buu02549
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Feb 06, 2008 | HP Officejet 5610 All-In-One InkJet...
513 people viewed this question
jasbo
jasbo
