Question about Tools & Hardware - Others
New model 8529 will not run, what to do?
Router has never had a bit in it, when plugged in will not run--tried other router in plug, it ran, tried different sockets also...just will not run, what can I do ?
  • Anonymous Apr 01, 2009
    i dropped my router on the floor and now it will not run.
    Sergeant:
  • 359 Answers
Make sure you don't have the Collette in the lock position
Posted on Dec 05, 2008
Can't start my 2008 yamaha 540 was cold that day ran out gas put gas. Didn't start
Try lots of gas line antifreeze and change the fuel filter. Spark plugs should be dry, you may have plugged filter or water in the gas or both
Jan 28, 2015 | Yamaha 2005 VK 540 III Base
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
I have a laptop running vista ultimate 32 bit version and i am having problems connecting to the internet. It says I am connected but will browse the internet. Are the troubleshooting steps the same as...
The steps are the same though the menus and screens you go through to do them are a bit different from XP. Pretty much all the software steps you can do are covered by the troubleshooter in vista and 7 though, so if you have ran that without a solution, then the likelyhood that it's a setting in windows causing the issue is fairly low.
First I would confirm that your connection is actually working. If you are attempting to connect the laptop with wireless it is not uncommon for routers to stop responding correctly to wireless clients, or even for the wireless portion of a router to die while wired connections still work perfectly. Try plugging the laptop in with a wire and see if you still have the same problem. If wired worked but wireless did not, then unplug your router, wait about 30 seconds and plug it back in. Retry the wireless and if it still does not work then a replacement router will be required to use wireless, though you could get a second cable and use it wired until you do replace it.
Aug 25, 2011 | Microsoft Windows Vista Ultimate Edition
I am trying to install F5D7051 Wireless G Plus USB Adapter on windows 7 but i have several problems .i tried to install the drivers from the cd that came with the package but i couldnt run the program.i...
You don't actually need a driver to set it up. Just plug it into your network, then browse to its URL (likely 192.168.1.1, but could be 192.168.0.1, or 192.168.2.1). Then just follow the prompts to configure it. Hope that helps.
Feb 20, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We plugged in the modem yesterday and ran the router and set up our wireless network. Everything was working fine on both our computers with our wireless network and neither one of us were plugged into the...
Your Wireless Router may have its name not broadcasting or hidden, check in the settings if it's hidden then manually connect your P.C.'s Laptops ,you won't find it using 'search for network'. Just right click on wireless icon near clock, select 'Open network and sharing center' and right click it. Now select 'Set up a new connection or network', Select 'Manually connect to a wireless network' and fill in the gaps. should work fingers crossed.
Aug 24, 2010 | D-Link DI 514 Wireless Router (DI-514)
Sometimes the internet goes down. If I unplug the wireless router and plug it back up; it comes back up. We are using a Enhanced wireless router.
For some reason this happens with most models of routers, and it seems that they are getting a slight bit old so the signal might drop, but there might be some interference or traffic that is knocking the signal down. What you are doing should help but I think it might be time to get a new router, or try reseting this one to see if it helps. Please, if you do come back, can you look for a sticker on the device that has the model number and post it here?
Dec 08, 2009 | Belkin Computers & Internet
In trying to install my Linksys router, it shows or says that says that my network adapter needs to be plugged in? It was working fine, and then when I tried to pull up my Yahoo page one day it was...
Try clearing out your cache, cookies, and temperary Internet folders. Click start run and type cmd and press enter. Then type ipconfig /release wait a little bit and then tyep ipconfig /renew.
Aug 10, 2009 | Linksys Wireless-G WRT54G Router
Router not connecting
The problem here is that the WRT54GS is an old model, so naturally the installation CD is also old. This is especially a problem if you are running Vista. I ran into the same problem when I was installing my wireless card; my computer would detect it on boot up, but when I installed the drivers from the CD, it said the card wasn't plugged in.
The solution would be to download the lastest installation and driver files from the LinkSys website and use those instead of the installation CD that came with it. You may have to hunt for it, as some companies would rather push new products than update older ones, but since the router is still on the market, they should have the updated drivers and installation files.
Feb 11, 2009 | Linksys Wireless-G WRT54GS Router...
1613EVS Plunge Router will not operate. Does not start !
hello- had same problem with similar model-- problem is definitely DUST INSIDE THE SWITCH, it must be blown out with compressed air- i had this done at a repair shop (for free) so i don't know if they had to disassemble anything- hope this is helpful
john
Nov 16, 2008 | Bosch Plunge Router
Router Repair
Unp[lugt the unit and remove the brushes then blow out the brush cavity and try it. If no fix, unplug it and remove the switch and bypass it by wiring direct being very careful as the high rpm generates lots of torque. Don't let the unit get away from you during this exercize. Next I would check to make sure the cord is not causiong the proper. The last thing would be to check the field wiring as a last ditch effort.
Feb 12, 2008 | Dewalt DW746X 10" woodworker's table saw...
Tools & Hardware - Others Logo
81 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
