Question about Espresso RMI La Cimbali Espresso Machine
Display says to press cleaning button. Which one is it?
We have a La Cimbala Pasquini M2 barsystem s/10 expresso machine. The disply says to press cleaning button but we don't know which one it is or if it is a combination of buttons. Can you help?
    Problem Solver:
  • 18 Answers
Top 2nd row left. The small button with the filled cup icon. It's for short wash (2 mins) and full wash cycle (after opening the pill drop chute) which takes 8 mins to complete. Instructions in your operator's manual.
Posted on Feb 10, 2010
  • Alicia
    Alicia May 22, 2015
    This did not work the wash cycle starts to run but nothing happens
Why hot water is not hot steaming like before from the LaCimbali M2 Barsystem cappuccino machine
If this machine has been in use for over 6 months then it will need servicing. The hot water system has calcified which will need cleaning or replacement.
ukeboy57
Jun 10, 2014 | Espresso RMI La Cimbali Espresso Machine
How do I set the coffee dose?
Too detailed for direct answer. Get operator's manual for dose instructions. Some machines may require programing key (service tech only)
Sorry for this answer as the dosing control is in-bedded with all dosing variances which is considerable. Though with practice it's possible to set it. Have you service tech walk you though the 'operator' or 'customer' programing steps.
Dec 30, 2013 | Espresso RMI La Cimbali Espresso Machine
I am repairing a LaCimbali M2 BarSystem that has a broken gear (Nylon) that transfers Torque from the Motor to the drive shaft on the grinder. Can this gear be purchased separately?
Sorry no, the gear drive assembly comes complete with the motor drive. Broken gear is usually caused by something getting into the dose chamber. I've found may an object stuck in the chamber, Don't leave stuff on top of the machine. Don't use hard cleaning pills (check old coffee 'pucks' for unmelted pills) Gross overfilling of coffee will also break gear. Check for oversized coffee pucks (double dosed?)
ukeboy57
Oct 11, 2010 | Espresso RMI La Cimbali Espresso Machine
The grinds are too course on my La Cimbali M2 Barsystem. Where is the lever, and how do you move the lever in order to make the espresso grinds finer?
The ginder udjustment for M2 is behind the coffee bean hopper. It is a small level hundle. You have to pull it up and rotate it step by step clockwise for more fine.
May 08, 2010 | Espresso RMI La Cimbali Espresso Machine
What are the maintenance procedures for the Pasquini mod. GMMC coffee grinder?
If this is in reference to the Pasquini K2 Moka Grinder, they are pretty much maintence free. Remove the beans/hopper, then pushing the button on left hand side down, you can unscrew the dial counter-clockwise. This will give you access to the top/bottom mills. Use a wire brush the machine came with to clean the coffee off from the mills teeth which builds up over time. Then reassumble and readjust your grind for the beans you are using.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Apr 06, 2010 | Pasquini Moka Coffee Grinder
We have a La Cimbala M2 barsytem that indicates press cleaning button, where is it?
The top left button on the 2nd row of smaller buttons. It has a filled cup as an icon. press and hold until screen says 'short wash' or group wash. There is also a full cycle washing that is required some time during the day usually at night or start of a work shift. This requires the opening of the 'de-cafe' or pill drop chute. It's a small black slide about the size of a pack of gum. open it and drop a cleaning pill then close it. the panel buttons will blink and the screen will say press cleaning button. press and hold the wash button (as previously mentioned) till the cycle starts to clean. Release button and allow 8 mins for the cycle to complete. This will keep the 'clean cycle' clear until the next shift or next day when it needs to be done again. These instructions should be in your manual that came with the machine.
Sep 27, 2009 | Espresso RMI La Cimbali Espresso Machine
My barsystem m2 machine shows that it needs to be serviced.
Check out this site it will give you a list of all the dealers.
http://www.cimbali.it/eng/contatti_network.asp
Apr 22, 2009 | Espresso RMI La Cimbali Espresso Machine
Need instructions for la barista tronik 3 group expresso machine.
do you need calibration for brewing??? if it is so than you can try this instructions:
Hold down the stop button for 8-10 seconds or until you hear the faint beeping sound, press button to program when you get the correct level press stop button. On some models you have to hold the button until you get the correct level then release. When you are done programming press stop button a second time to exit program mode.
PS : this solution works at many of older machines, as Emonec, la Cimbali.... THIS SOLUTION WHAS POSTED TO ME FROM
ES WORLD
Mar 04, 2009 | Coffee Makers & Espresso Machines
Leaking from the grouphead
The fix to this problem is replacing the group head replacement done every 8 months to a year. The part number is #90907 $4.50+shipping and I have this in stock.
Feb 18, 2009 | Pasquini Livia 90 Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
992 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
