Time and date
Hi there got a fujitsu siemens m1405amilo. the cmos settings for time and date keep coming up not set every time i turn on the computer??
i have set these but they keep coming back any ideas?
  • 1 more comment
  • deanmason_2 Dec 04, 2008
    thanks alot how much will it cost and could ido it myself and were do i get the battery from thank you
    thank you u have sorted my problem one more qustion a box appears when i sighn in 2 messenger saying an error has acured on this page it says continue writing yes? or no? then its fine its just the box that has only just started coming up? thank you
    nice1!!!!!
  • 124 Answers
The cmos battery is probably dead. It'll need to be replaced. Generally, it's a 2032 battery (button cell about the size of a quarter).
Posted on Dec 04, 2008
  • Jason Edinger Dec 04, 2008
    Not sure with a laptop how to do it. If you google your laptop model and service manual (ie, nc6220 service manual), you should be able to get it.
    As for the battery itself, try Radio Shack? Any place that sells button cell batteries should be fine.
    Usually you can just click No and be fine. If you don't use messenger, I'd suggest uninstalling it. Or even using something like Pidgin (www.pidgin.net) or trillian that can connect to yahoo, aim, msn, gmail, all at the same time.
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
What is mean CMOS battery use for in computer motherboard ?
CMOS stands for Complementary Metal-Oxide Semiconductor. It is basically a chip in the mother board that stores information such as your system hardware settings and date and time. It is powered by a battery the size of a small coin. Without the CMOS battery, your computer will revert to original manufacture hard ware settings every time you turn on your computer. If you keep having to set the correct date and time of your computer every time you turn it on, then it's time to replace the CMOS battery. I hope that helps.
Nov 27, 2014 | Computers & Internet
HI! Fujitsu Siemens S7020WL1 doesn't start, black screen and 3 beeps, 1 long and 2 short. Any hint what the problem might be? Appreciate, Leuben (leuben@eol.ca)
It differs between manufacturer slightly but usually 1 long and 2 short beep codes often means that there is a problem with the video card/graphics card of your computer. This could be bad news for a laptop, as most of them do not have discrete video cards that can be replaced.
Sep 12, 2011 | Fujitsu LifeBook® S7020 (FPCM42414) PC...
Hi how can i reset r610 cmos? i taked off the battery and put it again on it's slot but nothing happened
The Fujitsu Siemens Celsius R610 desktop computer uses a Fujitsu D1357 motherboard. (S26361-D1357 actually)
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/professionalpc/Celsius/R6xx/R6xx.htm#specs
On this page I would like you to go down to the heading - Motherboard, and click on the D1357 to the right.
A PDF file for the motherboard manual will download.
In Bookmarks click on the + sign to the left of -
Overview Board, Jumpers and Connectors.
In the drop down list click on -
Clear CMOS Jumper (J28)
Increase the view size so that you can see it clearly. Click on the + sign at the top of the PDF file.
1) Computer unplugged from power.
2) The jumper goes across the two pins of J28.
(By the default factory settings there is no jumper across these two pins. The jumper may be just sitting on one pin. Kept there to use for this function. {Clearing CMOS settings}
If no jumper is present see if you can borrow one off of a harddrive, etc. Be SURE to put it back on the device afterwards!)
3) Leave the jumper on the two pins for several seconds. I would wait at least five.
4) Remove the jumper. If it was present before, and sitting on just one pin, put it back.
5) Plug the computer back into power. WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Fujitsu Siemens Celsius R610 PC Desktop
My main battery stopped working about 6mnths ago and the last couple of days when i turn my laptop on it asks for the time and date to be set all the time can any 1 pls help
Hi, this sounds like the main cmos battery inside the laptop is flat.
It is a thumb nail size battery that holds the settings for you bios where the time and date is adjusted.
To be honest, unless you know how to disassemble the laptop then i would advise you to take it to a repair shop.
Some time the cmos battery is located under the RAM section, but i can't guarantee it.
Hope this has helped in some way.
Regards - Anthony
Jan 31, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
When I turn my computer on, I get an istant error message: CMOS setttings error. Any idea what to do?
I THINK YOUR MOTHERBOARD BATTERY MAY BE DAMAGED OR DOWN. YOU HAVE TO REPALCE THE BATTERY AND TRY AGAIN TO START THE PC.
Oct 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Date reverting back to 2002
Somewhere inside your laptop is a small watch battery. Refer to the manual to find it's location. This battery powers CMOS. Find this battery and replace it with a new one and it will solve your problem.
Aug 04, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu siemens Amilo D 7830 CMOS battery keeps dieing
As an update to this, I've been able to boot it up a few times since posting this, but it never gets as far as being able to boot up an entire operating system before freezing.
Nov 19, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
The clock on my Fujitsu Siemens Scalio L computer loses time.How can i fix it?
There is a small cell battery which keeps some data like TIME running and CMOS settings saved...even if the computer is whiched off...Your battery is weak now...replace it with a new one...
May 10, 2008 | Computers & Internet
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
