Heater cycles too often - Heating & Cooling
  • 833 Answers
I'm not sure what this means but I would suspect that the air filter is clogged..causing poor air flow.
Posted on Dec 04, 2008
My spa flips breaker at the 6 pm circulation. Why?
Does it trip on other programmed cycles? Or, do you only have the one circulation time? This one is odd, if it only trips during one of multiple cycles. It could happen this way: if you have two or more cycles programmed, and only the one 6:00 cycle has the option for the heater to come on, then you could have a bad heater element? But the situation would have to have the spa in economy mode. Because heater will work only when timed filter cycles are activated, and if a demand for heat is registered, the heater will come on,and in your case, breaker will trip. If in standard mode, the breaker will trip any time the spa comes on, when a demand for heat is registered, this is called "heat call" or call for heat. Good luck
Feb 28, 2015 | Pool & Spa
Why is inside of cabinet wet after dry cycle?
Need to use rinse aid for proper drying. If using rinse aid, might have a bad heater. Run it through a cycle, open it half way through the dry cycle and touch the heater with a wet rag. Should sizzle if the heater is good.
Sep 22, 2014 | KitchenAid KDTE104DSS Architect Series II...
Heater control valve function
no the heater control valves function is to stop coolant (water) flow through the heater core . there is a cycling switch on the low side a/c line or accumulator drier this cycling is to keep the evaporator from freezing up and it also cycles when system is low on refrigerant .
Jul 23, 2014 | 2000 Oldsmobile Bravada
Heater pops when heating on low cycle
not enough water flow the water is boiling inside heater
Apr 21, 2014 | Teledyne Laars Pool & Spa
Defrost Cycle on Fisher and paykel RF610
Malcolm, if you are indeed getting an F20 fault, this is a problem with the flapper heater. The flapper heater current is low.
First, Check the JST in-line connections for the flapper heater.
Second, Check the resistance of the heater. If open circuit, replace the heater.
Apr 20, 2014 | Refrigerators
Had problem with clean bilking light. I was able to reset with your help. But it keeps coming back after every cycle. Dishes are not drying as well. How can I fix this?
The flashing light indicates there is a heater issue caused by a failure of one or more of the following: (1) The heater. (2) Door switch. (3) Water high temperature limit switch. (4) Electronic control heater relay. (5) heater wire may have loosened from heater terminal and burned off. If the heater is of the round type, test this first.
Mar 05, 2012 | Whirlpool Dishwashers
My dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front...
Control is programmed to
stop the current cycle and
not allow any further
cycles if it suspects a
faulty heater (no
temperature increase
detected in heated
intervals). Control blinks
the Clean LED 7 times in
repetitive fashion and
disables the Start/Resume
key until cleared.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater
circuit.
■ Faulty heater drive
circuit on control.
Running Diagnostics clears the control and
allows it to operate again. If heating problem
is not corrected though, the control will stop
running again on next cycle. See below.
1. Unplug dishwasher or disconnect power.
2. Check all components and connections in
the water heating circuit or heat dry circuit.
■ Check resistance of heater.
■ Check resistances of all connections and
components between the control and
heater.
■ Check operation of heater and temperature
sensor in Diagnostics cycle.
Aug 26, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Sterling 200,000btu gas heater cycles on and off
Do you have an external Thermostat mounted
nearby? It could be that it is to close to the heater and the thermostat is causing it to short cycle
Jan 05, 2010 | Sterling RF45 Propane Gas Heater (45,000...
Regrig blows breaker in when entering defrost cycle, what is ohm of defrost heater?
21 ohms for a heater is not bad. I think what is happening is when the heater gets power and starts to heat the heater shorts to ground. causing it to throw the breaker.
Apr 15, 2009 | Refrigerators
Luke warm water on sanitize cycle, why?
remove lower kick panel and check wire connections to heater. 2 wires go to heater terminals and a harness connector goes to temp sensor in middle of heat terminals. may be green ground connection on another term. use multimeter and check resistence on heater. during cycle heater will take time to heat.
Mar 16, 2009 | GE WBVH6240F Front Load Washer
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
