Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
My roommate lost his manual for his 6.0 cordless phone system
How can we set the rings at 2 and quiet the rings??? When I push setup it says 2 rings but rings about a dozen times anyway.
Thanks, Rick
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of his Uniden DECT 6.0 system I can only suggest you (or he) select it from the list beginning here to download a copy of the manual.
Posted on Jan 15, 2013
SOURCE: Uniden 2.4 GHz cordless phone
http://www.uniden.com/products/productdetail.cfm?product=EXAI978
Follow this link.  On the right hand side of the page you will see a box with Owner's Manual.  Hit the English PDF file.  This will then give you the entire owner's manual.  Programming is on page 28.  P.S.  Learn to use the internet to search for these things.  Usually major companies have home pages with links to their owner's manuals.
Posted on Oct 20, 2007
patel352003
  • 192 Answers
SOURCE: Uniden corless phone says Do not disturb on screen
It seems problem of programming. You have to reset it. I can say that if you are enough knowledge of it's initial setup process you may tri by removing battery and again attach it with your phone. This will reset your phone on factory status. You may be loss your data stored but get working phone. Vote it how this fix your problem.
Posted on Jan 08, 2008
SOURCE: cordless phone setup instructions
I need to reset the greeting - Help
Posted on Oct 16, 2008
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Posted on Dec 17, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
How do I change the number of rings before it goes to voice mail
The manual is available from:
http://www.manualslib.com/download/678020/Vtech-Cs6859.html
( be sure to ignore the advertising large button
"start download" and use the smaller button "download"
across the top banner "downloads" "table of contents" etc. )
then enter the security-codes & click "Get Manual"
then click 'Download pdf'' etc. )
The directions to set the number of rings for the
Answering System are on page 51.
To summarize Setting the Number of Rings:
1. press [MENU]
2. scroll up/down to "Ans System" then press [select]
3. scroll up/down to "Ans System Setup" then press [select]
4. scroll up/down to "# of Rings" then press [select]
5. scroll through the choices, at desired one press [select]
6. press [off ] to conclude & exit
May 05, 2016 | Vtech CS6859 Cordless Answering System...
How do I extend the ringtone time of incoming calls on binatone lifestyle 1910
Most of the newer phones have a feature that quiets the ringtone when you touch the phone or move it. You can deactivate this feature in the settings menu. I hopes this helps you..
Nov 25, 2014 | Binatone Lifestyle 1910 Twin Cordless...
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
I would like to set my phone to ring up to 6 times instead of 2 rings then rolling over to voicemail.
The procedure for changing the ring count varies from model to model. Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Apr 12, 2011 | Uniden Cordless Phone
Hi There my uniden 5.8GHz Digital rings only twice before answer machine starts how do i extent the time of ringing? thanks
For the TRU9380, you can set the number of rings for the answering system from the handset. Press Menu/Clear and select Answ Setup. Then choose the Ring Time submenu. Move the cursor to select the number of rings (Toll Saver, 2, 4 or 6 Times). Press Select to save the setting; you will hear a confirmation tone. (Note: the answering machine must be on.) In Toll Saver, it picks up after 2 rings if you have new messages and after 4 rings, otherwise.
You can find the manual for most Uniden 5.8 GHz phones by looking up your model here: http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%205.8%20GHz%20Digital . Check here if you have a different model.
I hope this helps.
Feb 10, 2011 | Uniden Cordless Phone
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Can't turn off answering machine or change from 2 rings.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download the manual.
Jan 02, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
37 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
