I need to find a source for D-Link Part Number JTA3020A 5V-2A
  • dave807 Dec 09, 2008
    this is what i was looking for!
    Novelist:
  • 171 Answers
Almost all d-link routers use the same power adapter. All that's important is that it is 5v DC output, and at least 2.0A output current. So you should be able to pull an adapter from another router.
you don't actually need a REAL d-link adapter either, any adapter that matches those specs and fits the plug will work. Just beware, if you plug one in that doesn't match, you'll damage the device. I"ve found adapters like these at the local thrift store all the time.
Posted on Dec 06, 2008
I misplaced the power adapter for my mxq pro help
Android TV Box Power Supply Adapter 5V 2A AC/DC For M8S/M8S PRO/MXQ/MXQ PRO
5 VOLTS DC @ 2 AMPS... 95% sure it's a 3.5mm jack!
eBay:
Android TV Box Power Supply Adapter 5V 2A AC DC For M8S M8S PRO MXQ MXQ...
Dec 17, 2017 | Power Computers & Internet
I know I need a 5 volt dc power adapter but I don't know the size of the end piece that connects to the speaker can you help me thank you.
Jean, take the speaker with you to the source or electronics shop and they will match you up with proper universal adapter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
power adapters
Amazon com Universal 5V 1 2A AC Power Supply Electronics
5V Power Adapter eBay
http://www.walmart.com/c/kp/universal-ac-dc-adapters
Feb 27, 2016 | Audio Players & Recorders
What do they mean the input voltage range between the wall outlet and this adapter is ac 100v-240v, and the adapter's output voltage is DC 5V,2A
A lot of new computer hardware will accept regular 110-115v like most people have in their homes (USA) or high voltage 220 (mostly used for washer / dryers) or industrial use. Like in a factory. This unit accept both without worries of over loading. Some may even have a switch to swap back and forth. It actually only uses 5v and 2amps. Meaning a single 110-115 power strip can handle many plugs, because of the low voltage.
Aug 28, 2012 | ASUS Google Nexus 7 16GB Tablet 71B16
Where can i buy a switching adapter for our philips 10 in. digital frame? model DSA 12 PFA-05 FUS 050200 input 100-240 V output +5V
if you mean a switching adapter for your phillips 10 in. radio shack has an adapter set with multiple plugs and voltage and amps here is a link to one on amazon http://www.amazon.com/5V-1-2A-Universal-Power-Supply/dp/B001KU44HE that looking up your model should work. also walmart and best buy carry adapters with multiple plugs as well hope this helps let me know
Mar 14, 2011 | Philips Cameras
All I want is support of a 4 port usb hub. What is the voltage and amps of the power supply. Don't you support it any more.
The Standard voltage for USB is 5V and a USB 2.0 port on your computer will give you 1A.
I checked on eBay, a good source of information on what is available and several 4 port powered USB hubs are rated at 0.5A per port.
The ones that quote specifications on their power supplies say 5V 2A.
There is little support for them as there is very little in them that can go wrong, and if they are fail, it is simpler to replace them. One i saw while looking was under $15, shipped world wide.
Feb 06, 2011 | Computers & Internet
External drive power supply 3 wire code???
Hi there.
Have a look at this link for wiring instructions >>>>>
http://www.pc-user.co.uk/power_connectors.htm
Hope this helps and thanks for using FixYa!!
Apr 21, 2009 | Computers & Internet
WD hd won't start up when turned on until you plug into usb
i cant put a solution for this but try the exact software for the disk which it came with this can help.Im also trying for the software
Oct 27, 2008 | Western Digital (WD3200JS) 320 GB Hard...
ASUS P5GL-MX performance
Install new power system!
Thanks,]
Melcom Smit
Oct 04, 2008 | Computers & Internet
MY COMPUTER JUST STOPEED AND I NEED 2 KNOW THE SPECIFACAITIONS ON THE POWER SUPPLY
If you are using latest system you need
Ac input : 220vac 3a 50hz
450watt minimum
Atx 2.03
Atx 12v
Dc output
+5v 28a -5v 0.6a
+12v 15a -12v 0.6a
+3.3v 16a +5vsb 2a
Apr 16, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
