Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error U071 how do i solve about this error {more than one ink tank of the following color is installed} I have the same problem regarding error U071. I went to the canon website. Possibly it is a problem between Windows Vista and the Canon MP830 model (which is the one I have). There may be other models that are not working with Windows Vista also. Please check their site for your specific printer.
  • Anonymous Dec 17, 2008
    I have the same problem on my MP830. I think its a cartridge chip problem. My error is on the magenta colour cartridge. I'm pretty sure that the chips for each colour cartridge are not interchangeable since the problem remains when i swap the cartridges over. The error code is still for the same slot and colour position. I will try and buy another magenta cartridge with a new chip and see if this solves the problem. Watch this space. Regards, Az!
  • oboline Mar 30, 2009
    I have the same problem. It's with the Cyan color cartridge. I just can't get past it. I have genuine canon cartridges. Do you think getting a new cartridge will solve the problem or is it some thing else?
  • 421 Answers
Make sure that the inks are not re-manuafactured ones with chips taken off genuine canon inks. It is possible that the wrong chips could be fitted to the wrong colours.
Posted on Dec 07, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
If an error message is displayed on the LCD, take the corresponding action described below.
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error U071 ;more than one ink tank for black
your chip may get something wrong if the sensor is dirty or some ink goes over it!try to pull out the Bk carige and put it back again if not help try same but get some tishue and clean up the chip contact serfice!
Aug 24, 2009 | Canon Pixma MP500 All-In-One InkJet...
Won't let me print and it says U071
That error is from a defective ink cartridge, if all are installed correctly. Most often I've found the 5BK cartridge to be defective. If the store won't exchange it you might call Canon at 1-800 OK canon
Jun 23, 2009 | Canon MP830 All-In-One Printer
I have error U071. I have been refilling the
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Feb 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error U140 & U071 for Cannon pixma mp800
Thanks for checking back my printer problem. Solved the problem--purchased a new printer.My big problem now is repairs on my Mitsubishi WD 52725. I do not think I will buy a new one of those.I will purchase your help package for help with that. Please advise.
Nov 26, 2008 | Canon Pixma MP800 All-In-One InkJet...
Printing Cartridge error
I've seen this problem before and it turned out to be a faulty chip on the cartridge as opposed to a problem with the printer. Canon should replace the cartridge free of charge if this happens.
Nov 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
Nov 06, 2008 | Office Equipment & Supplies
Canon PIXMA MP830 All-In-One InkJet Printer Logo
327 people viewed this question
old marine
old marine
