Question about Ovens
We have a 5 burner GE Profile oventop. The clicking from the electric starter doesn't stop unless we unplug the unit. Any suggestions on how to get the clicking to stop?
  • 833 Answers
You have a short in one of the contacts on one of the controls.  Remove the cover to the cooktop.  Visually inspect.  If necessary, disconnect the wires from the controls one at a time....they're all in parallel until you stop the symptom.  Be careful around the wiring...turn off power before touching any uninsulated wires.
Posted on Dec 04, 2008
Need to replace burner on ge profile jsp47
Hi pauli1598, if you are thinking of doing it yourself, let me suggest a quick look at the following link you'll find a complete procedure there and if you don't have a meter you can always exchange the defective element(burner) with one that is working just make sure it is defective. You can always find replacement electric elements in your local appliance parts srore or sears or if you prefer on line ordering you will need the complete brand name and model number.
Jan 08, 2010 | GE Profile JSP47 Electric Single Oven
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Igniters will not stop clicking.
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Burner keeps cycling on to high when OFF
Safety will require expert repair or replacing the oven.
Oct 21, 2007 | GE Profile JTP18 Electric Single Oven
Gas Stove - Electric Starter
Just happened to me. I unplugged the electric starter, wiped up the water, took off burners, etc., and placed a fan over the stove. After about 3 hours, I plugged in starter and the clicking is no longer.
Sep 23, 2007 | Ovens
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
