I get very low speed - Computers & Internet
  • Christian Cabalfin
    Christian Cabalfin May 11, 2010
    Please be more specific. What you mean very low speed? On what kind of connection, performance etcc... TY
    HOPE I CAN HELP
  • Betty Wood
    Betty Wood May 11, 2010
    Need more info
  • 961 Answers
Follow
bob_computer solution.
Posted on Feb 28, 2011
  • 3,153 Answers
Some computers can be slow or short of hard drive space for quite simple reasons.
Windows and other program hide temporary files in lots of different places
The best option is not always a program or utility and if you want to do as much as you can for FREE like I do then you have a few options.
1. First you need to be in windows explorer.
2. Click TOOLS and FOLDER OPTIONS
3. Now click the VIEW tab
4. Tick the Show Hidden Files And Folders option
Unpick Hide Protected Operating System Files (it may warn you but you can ignore it)
5. Click APPLY then OK
6. NOTE some files may not delete this is OK Also DO NOT DELETE the folder itself where mentioned for cleaning.
7. Using windows explorer go into the WINDOWS folder and look for a directory called TEMP (it is possible there may be more than one)
8. Select all the contents and delete them. Do the same for any other temp folder e.g. temp000
9. Now navigate to Documents and Settings
There are quite a few folders in here that can be cleaned up
10. Look for folders named "Local Settings" In there you will find more TEMP folders that can be cleaned out
11. Now look inside the Temporary Internet Files. Delete anything EXCEPT cookies. Otherwise passwords for some sites you have stored may need you to type the password again.
12. Do this for each user / profile you see.
13. Now check the C: drive itself and see if there are any Temp folders and clean those out too
To prevent accidental deletion of any files windows needs you should go back to step (4) and change the two settings back to their original
Posted on Sep 21, 2009
    President:
  • 1,912 Answers
Simple steps to accelerate internet speed little,just do this delete all temp files,give clear cache every day..u will feel the speed
to test ur speed just reach http://www.ip-details.com/internet-speed-test/
  • 23 Answers
Low internet speed? Computer running slow? If this has to do with your internet you may want to contact your ISP and discuss with them why you are having low speeds. If this is not related to the internet then you should try upgrading RAM and possibly Processor speed.
Posted on Dec 06, 2008
A diesel engin uses diesel fuel generates low power at low speed
Increase the speed for constand power output, or check the load it maybe more than the genset can power.
Apr 03, 2017 | Speed Electrical Supplies
Blower just started staying on - furnace has been turned of for 6 months
This is a diagram of a blower relay and a fan motor, the normally closed fan relay switch goes to the low speed which is the Heat speed, the low speed is controllled by a temperature delay depicted in the low speed circuit.
The normally open fan relay switch goes to the high speed, which is the AC modes speed , also if you run the fan continuously via the fan switch on the thermostat this is also to high speed.
I suspect the temperature delay's on setting is being reached thus cycling the low speed of the fan.
Nov 08, 2015 | Heating & Cooling
Why won't one of the spa motors start at low speed?
bad two speed relay on that motor
Oct 10, 2015 | Pool & Spa
MY PUMP WILL ONLY RUN ON LOW SPEED ( NEUTRAL AND BLACK) . PUMP IS MARKED 230 v , ? DOES THIS RUN ON NEUTRAL TO 120 FOR LOW SPEED AND NEUTRAL TO 120 FOR HIGH SPEED AND USE SEPERATE WINDINGS OR IS HIGH SPEED...
If this is 220v then your netural is not a netural but a common. Meaning it is common 110v to both the high and low speeds of pump. The high and low speed are the same leg of the 220v or the other 110v leg they just separate at the clock or high/ low switch. Then yes they run through separate windings for high and low.
If your not getting high speed it could be the high speed winding but be sure to check your switch and high speed lead first before doing anything else.
Sep 19, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
How do I determine when to yse high speed /low
High spped for drilling
Low speed for driving scrrews.
Sep 05, 2009 | Drills
I have a 2 speed spa motor (K48m2a4) that stopped working at low speed. going to high speed only has circulating power.
Either the low speed circuit is defective or a relay is inoperative. If you feel confident , you could switch the low and high speed leads on terminal plate. The high speed jet button would activate low speed on pump if motor is good.
Aug 01, 2009 | Pool & Spa
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Please explain hyundai terracan 2002 fault codes p1730 front speed sensor low input, p1732,p1734 low input,how to find problem, low range there is no opperation at all, cheers ,clive.ps in the model...
P1730 Front Speed Sensor - Low Input
P1732 Rear Speed Sensor - Low Input
P1734 Speed Sensor Reference - Low
These are all references to Electronic Stability Control or ABS systems. If there's no problem with wiring, then you could safely assume the speed sensors are bad.
Apr 30, 2009 | 2002 Hyundai Tucson
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
