Question about Acer TravelMate 2300 Notebook
The sound is cutting in and out and the system runs much slower
Travelmate 2411 on (long) bootup and any audio (speaker or headphones) the sound is intermittent int-er--mit---tent. the system is sloooooooow.
    Scholar:
  • 188 Answers
I'm assuming you are running XP. Here are some things to try:
1. In your web browser (Internet explorer) click on the 'tools' menu
2. click on 'Internet Options'
3. Under browser history click on 'delete'
4. The first 2 options are to delete temporary files and delete cookies. Do those two things.
5. Reboot
6. 'Start' 'All programs' 'accessories' 'system tools' 'defrag' and run the defrag program.
7. reboot.
8. Virus scan all files on your computer.
9. Reboot.
I will be notified if you post any problems with the above. Your computer should run faster.
Posted on Dec 12, 2008
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
No sound on speakers, only on earphones.
Indicates to me that the headphone socket is faulty, assuming that previous to this putting a headphone jack caused the main speakers to cut off.
Not an expensive repair.
Aug 07, 2013 | JVC MX-J900 CD Shelf System
No sound in speakers, do i need new speakers or is it something i can fix?
Try a pair of headphones. If you can't hear any sound it's not the speakers. If you can hear sound, it still might not be the speakers. As sometimes headphone sockets which cut the speakers off when headphones are plugged in, can go faulty. To test any loudspeaker connect a 1.5 volt battery accross it's terminals for a few seconds. It should POP.
Feb 27, 2013 | Audio Players & Recorders
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
I am using acer travelmate 5520-5678 and the external speaker only works from the left side. Both works when I connect my headset..
sounds like the spaker on the left hand side is unhooked, blown or the pre-amp in the laptop that drives the speakers is bad, headphones are uneffected as it is a seperate system.
Joe
May 26, 2009 | Acer TravelMate 5520-5678 Notebook
Acer travelmate 3270 speakers and headphones detection problem
Are they wireless speakers? You might try updating the sound card driver.
Jun 10, 2008 | Audio Players & Recorders
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
